Component: Simulation LED Template (Indicators)
| Author | Matrix Ltd |
| Version | 1.4 (Release) |
| Category | Indicators |
Base for creating simulation LEDs and other on/off visual indicators. Choose a 'Target Object' that will change colour when the pin changes; if multiple objects must change color, group them, and target the group. When 'Auto off color" is selected, changing the 'on color' will automatically choose an off color by reducing the intensity of the on color.
This component can be used as a base to create child components
The following components all inherit the traits of Simulation LED Template:
TurnOn
Turn the LED off.
TurnOff
Turn the LED on.
Simulation macro reference
Target Object
This property is of type Panel object and can be referenced with the variable name target_object.
Set a target object to be the illuminating part of the LED.
To change the colour of multiple objects, group them first, then target the group.
This property is of type Fixed list of ints and can be referenced with the variable name component_label1::show_label.
Decide what label to show...
None - no labels are displayed
Name - shows the component's name
Property - shows a property value of the component (a field for the property name will appear below)
On Color
This property is of type Color picker and can be referenced with the variable name on_color.
The color of the LED when it is turned on.
Off Color
This property is of type Color picker and can be referenced with the variable name off_color.
The color of the LED when it is turned off.
Auto Off Color
This property is of type True or false and can be referenced with the variable name auto_off.
When this is selected, the off color is automatically set to a reduced intensity version of the on color.
Startup State
This property is of type Fixed list of ints and can be referenced with the variable name StartupState.
Default state of the indicator when loading the project or starting the simulation runtime.
