Component: DAC (AD5662) (Analog Output)
Revision as of 10:00, 7 March 2019 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Analog Output
Image DAC (AD5662) component
16-bit external DAC connected to the microcontroller using SPI.
OutputDAC
Outputs a value to the DAC,
UINT Output
Range: 0-65535 / 0=0V / 65535=VCC
Initialise the SPI bus ready for communications,
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimulateComms.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
