Component: BBC Weather Forecast (Comms: IoT/Cloud)
| Author | MatrixTSL |
| Version | 1.0 (Release) |
| Category | Comms: IoT/Cloud |
Easily allows you to collect three day forecasted weather metrics for your area using the BBC Weather data service. Supports Min/Max temperature, Wind Direction, Wind Speed, Visibility, Pressure, Humidty, UV Risk, Pollution and Sun Rise/Set times for your selected area.
Here is a basic example to read the three day forecast data and report the information on a graphical display.
The location can be set by adjusting the BBC Weather location property, see the component property tooltips for more information on how to do this.
On an embedded device you would need a TCP/IP component to allow the communications to the BBC server. This then links to the Network Comms component.
GetDaySummary
Gets the summary of the currently selected day as a string.
GetMaxTemperature
Reads the forecast maximum temperature in the selected scale for the selected day.
- BOOL Scale
- 0 = Celcius, 1 = Farenheit
GetVisibility
Reads the forecast visibility for the selected day.
GetMinTemperature
Reads the forecast minimum temperature in the selected scale for the selected day.
- BOOL Scale
GetWindDirection
Reads the forecast wind direction as a string for the selected day.
RequestData
Requests data about your selected location from the BBC weather service.
Returns true if the request was successful.
Must be called before trying to call any of the GetXXX macros.
- BOOL : Returns true if the operation is a success, else false
GetPollution
Reads the forecast pollution as a string for the selected day.
GetSunset
Reads the forecast sunset time as a string for the selected day.
GetHumidity
Reads the forecast humidity in Relative Humdity for the selected day.
GetDayName
Gets the name of the currently selected day as a string.
GetWindSpeed
Reads the reported wind speed in MPH for the selected day.
SetLocationCode
Allows the location code to be altered from the default location code set in the component properties.
After changing the location the RequestData macro must be called to refresh the forecast variables.
- <- STRING NewLocation
- New location string, see Location property tooltip for more info.
GetSunrise
Reads the forecast sunrise time as a string for the selected day.
GetPressure
Reads the forecast air pressure in milli bar (mb) for the selected day.
SetForecastDay
Chooses which day of the three day forecast to look at.
- BYTE Day
- 0 = Today, 1 = Tomorrow, 2 = Day After Tomorrow
GetUVRisk
Reads the forecast UV Risk for the selected day.
GetLocationName
Reads the reported location name as a string.
Sets up the component ready to collect weather data.
Simulation macro reference
Network Comms Component
This property is of type Panel object and can be referenced with the variable name NetworkCommsComp.
Network Communications component to use as the bridge to the TCP/IP network.
BBC IP Address
This property is of type Line of text and can be referenced with the variable name IPAddr.
IP Address linked to the following URL: weather-broker-cdn.api.bbci.co.uk
Location Code
This property is of type Line of text and can be referenced with the variable name Location.
BBC code for your area.
In a web browser go to www.bbc.co.uk/weather/
Then type in your city in the search bar and your code will be shown at the end of the URL.
For example Manchester in the UK = 2643123
In the UK you can also use the first half of your post code, e.g. HX1
Receive Timeout
This property is of type Unsigned integer and can be referenced with the variable name RxTimeout.
Maximum time to wait for valid incoming data.
