Component: Digital Potentiometer (X9Cx0x) (Analog Output)
Revision as of 11:57, 25 February 2020 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Analog Output
Image Digital Potentiometer (X9Cx0x) component
The X9Cx0x device range supports a digital potentiometers outputs. 100 possible wiper tap points available. Supported devices include X9C102, X9C103, X9C104, X9C503.
IncrementWiper
Increments a single volatile wiper value
This macro has no parameters
DecrementWiper
Decrements a single volatile wiper value
DecrementXTimes
Decrements the wiper value the specified number of times
BYTE Count
Range: 1-99
IncrementXTimes
Increments the wiper value the specified number of times
BYTE Count
Range: 1-99
Simulation macro reference
CS Pin
This property is of type Single digital pin and can be referenced with the variable name CS_Pin.
Chip Select Pin, Active Low
Increment Pin
This property is of type Single digital pin and can be referenced with the variable name Inc_Pin.
Increment Pin, Active Low
Up/Down Pin
This property is of type Single digital pin and can be referenced with the variable name UD_Pin.
Up Down Pin, Low = Down, High = Up
