Component: Modbus Slave (SCADA) (Comms: System)
| Version | 1.0 (Release) |
| Category | Comms: System |
Modbus Slave (SCADA) component
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
ReadHoldingRegister
Reads the value of a single holding register.
- UINT Address
- Coil Address
ReadCoilStates
Reads the state of a single digital coil.
Can pack a max of 8-bits together in a single operation
- UINT StartAddress
- Coil Address Range 0 to (NumCoils - 1)
- BYTE AddressCount
- Range 1-8
ReadAnalogueInput
Reads the value of a single analogue input.
- UINT Address
- Coil Address
ReadInputStates
Reads the state of a single digital input.
- UINT StartAddress
- BYTE AddressCount
- Range 1-8
SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified
in the component property. The number of bytes used for the address is fixed by the
Slave ID Bytes property to save on RAM usage.
- UINT SlaveAddress
SetCoilState
Sets the state of a single digital coil.
- UINT Address
- Coil Address
- BYTE State
- 0=off, 1=on
ChangeFrameType
Default frame type is the type set in the component properties.
- BYTE Type
- 0 = Modbus RTU / 1 = Modbus ASCII
SetInputState
Sets the state of a single digital input.
- UINT Address
- Coil Address
- BYTE State
- 0=off, 1=on
SetHoldingRegister
Sets the state of a single holding register.
- UINT Address
- Coil Address
- UINT Value
- Analogue Value range 0 - 65535
CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply.
Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
GetLastIncoming
Gets a value from the last incoming command.
Index 0 = 0 Read / 1 Write
Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register
Index 2 = Address
Index 3 = Number
SetAnalogueInput
Sets the state of a single analogue input.
- UINT Address
- Coil Address
- UINT Value
Starts up the UART to allow communications and initialises the states of the various
Modbus Coils, Inputs and Registers to 0.
Simulation macro reference
Frame Type
This property is of type Fixed list of ints and can be referenced with the variable name FrameType.
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name ReceiveBufferSize.
Receive Timeout
This property is of type Unsigned integer and can be referenced with the variable name Timeout.
Length in milliseconds to wait for additional bytes to be received when checking for incoming messages.
Slave ID Bytes
This property is of type Unsigned integer and can be referenced with the variable name AddressBytes.
Slave Address
This property is of type Unsigned integer and can be referenced with the variable name SlaveAddress.
Reply Delay
This property is of type Unsigned integer and can be referenced with the variable name ReplyDelay.
Delay in micro seconds to wait before transmitting a reply
Maintain Stats
This property is of type True or false and can be referenced with the variable name Stats.
Controls if the last command from the master is logged allowing for easier value updates.
No - Do not log commands
Yes - Commands are logged and available via the GetLastIncoming macro
This property is of type True or false and can be referenced with the variable name scada_uart1::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name scada_uart1::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name scada_uart1::DataSource.
Simulation data source used to allow the component to connect to various remote devices
Nothing - Simulation data is ignored
COM port - Routes the communication data to and from a physical or virtual COM port
Injector - Routes the communication data via a data injector component on the Panel.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name scada_uart1::com_port.
Lists all the current available COM port hardware on your PC.
This property is of type Unsigned integer and can be referenced with the variable name scada_uart1::baud.
COM port data rate in bits per second
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrCoil.
Start address of the Modbus coils. Referenced from 0.
For example
Slave 1 might have 100 coils addressed 0-99 Start Address = 0
Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrCoil.
Specifies how many Coils are available on the slave.
Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrDI.
Start address of the Modbus digital inputs. Referenced from 0.
For example
Slave 1 might have 100 inputs addressed 0-99 Start Address = 0
Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrDI.
Specifies how many Digital Inputs are available on the slave.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrAI.
Start address of the Modbus analogue inputs. Referenced from 0.
For example
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrAI.
Specifies how many 16-bit analogue inputs are available on the slave.
Each address consumes two RAM Bytes.
Starting Address
This property is of type Unsigned integer and can be referenced with the variable name StartAdrReg.
Start address of the Modbus registers. Referenced from 0.
For example
Slave 1 might have 100 registers addressed 0-99 Start Address = 0
Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
This property is of type Unsigned integer and can be referenced with the variable name NumAdrReg.
Specifies how many 16-bit holding registers are available on the slave.
