App Developer
About App Developer
In Flowcode v8, we introduced significant new functionality that we called the “SCADA” feature. In v9 we decided to rename this to “App Developer” because the old name did not explain its full potential. App Developer allows you to easily create programs to control and monitor devices external to the PC. But it is much more than that. Flowcode App Developer runs on a Windows PC in your office or factory. But it is designed to make applications that work everywhere: on your desk, in your building, in your town, across the world.
Flowcode App Developer contains a large number of communication components that allow you to create distributed control, data gathering and analytical systems.
Flowcode App Developer uses the same programming interface as Flowcode Embedded. So if you know Flowcode you can now easily design Windows Apps for your own use or for royalty free distribution to others.
A key part of Flowcode App Developer is to interface to multiple hardware systems using APIs. Support for popular USB, Bluetooth, and Web based hardware platforms like Modbus PLCs, Arduino, Raspberry Pi, Nest and other systems is provided.
Flowcode App Developer is a paid for software application. It allows customers to create run time free apps which can be shared with many users.
Examples of App Developer applications
App Developer is a programming language that can be used for many applications. It is particularly useful for creating control, data gathering and analysis systems: local and remote.
Desk based
An electronic circuit board under test. is placed in a jig which connects it to a power source, a MIAC with a Flowcode Embedded program, an Arduino Uno with a Flowcode Embedded program and a TTI signal generator. The Flowcode App is designed to run a series of tests on the hardware by controlling the PSU and the embedded devices so they interact with the device and measure its responses. Results are logged to a local file on the hard drive.
Building based
An array of sensors monitor the environmental conditions within a greenhouse and display the status via internet on a mobile phone. Depending on these inputs, the application controls devices within the greenhouse such as heating/lighting and moisture levels to maintain optimum growing conditions for the plants. The system consists of three MIAC controllers linked by CAN bus with one linking to the PC using USB. The MIAC controllers are programmed with Flowcode Embedded.
World based
The PC application monitors building entry access and controls the environment. It uses keypads and/or locks with RFID tag readers built in, and grants or refuse access to certain doors and areas depending on the code given. It also monitors temperature and controls lights. A record of visitor and employee movements is recorded and can be displayed on web based devices to determine where they currently are in case of an emergency (e.g. evacuation due to a fire). Flowcode Embedded is used for developing the software for MIAC controller and the Raspberry pi custom IO and Broker. The Broker effectively acts as a web connected portal through which all data is stored and flows.
This section will go over how to start a SCADA project and start using one of the pre-built API's within Flowcode.
Once you have completed a SCADA project, you may wish to deploy it as a standalone program to allow none Flowcode users to use your SCADA program to communicate with your hardware.
Comprehensive table of target I/O devices which have a built in API within Matrix SCADA. This page will list the api source files, drivers and the embedded firmware required to send to the hardware to allow Matrix SCADA to communicate with the API.
Visit this page to get a comprehensive list of detailed Flowcode SCADA example projects. Download and see the code and try incorporate the ideas into your own SCADA projects.
