Component: Keypad (4x4) (Keypad)
| Version | 1.0 (Release) |
| Category | Keypad |
Preset keypad based around the 4 * 4 unit.
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
- BYTE : Index of the first key pressed.
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
- BYTE : ASCII code of the pressed switch (or 255 if none pressed)
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns the value 255.
- STRING : Single character representing the pressed key, or an empty string if none pressed.
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
- BYTE : Number return value of the pressed key, or 255 if none pressed.
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
- BYTE : Index of the pressed switch, or 255 if none pressed.
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Simulation macro reference
Column 1
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_col1.
Pin for the first column of keys.
Columns are counted from left to right.
Column 2
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_col2.
Pin for the second column of keys.
Column 3
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_col3.
Pin for the third column of keys.
Column 4
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_col4.
Pin for the fourth column of keys.
Row 1
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_row1.
Pin for the first row of keys.
Columns are counted from top to bottom by default - they can be counted from bottom to top
by changing the 'First Row' property in the 'Dimensions' section.
Row 2
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_row2.
Pin for the second row of keys.
Row 3
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_row3.
Pin for the third row of keys.
Row 4
This property is of type Single digital pin and can be referenced with the variable name keypad_base::pin_row4.
Pin for the fourth row of keys.
