Component: Display Manager (Graphical Library)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Author MatrixTSL
Version 1.0 (Release)
Category Graphical Library
Image Display Manager component
MoveObject
Moves an existing object to absolute coordinates on the screen.
UINT ObjectID
UINT X
UINT Y
ShiftObject
Shifts an existing object coordinates on the screen relative to the previous coordinates.
UINT ObjectID
INT X
INT Y
DrawObject
Draws a single object onto the display without clearing the display.
Doesn't draw a textfield component, this is done using the SetObjectText macro.
UINT ObjectID
ScaleObject
Changes the width and height of the selected Object
UINT ObjectID
UINT Width
UINT Height
RedrawAll
Clears the display and redraws all the content from the display manager objects.
Doesn't draw textfield components, this is done using the SetObjectText macro.
This macro has no parameters
SetObjectText
Assigns text to a single line text object and draws directly to the display.
Blanks the selected area first to ensure nothing from previous text is left behind.
UINT ObjectID
<- STRING Text
This parameter may be returned back to the caller
BYTE Font
CreateObject
Define an object on the graphical LCD.
Returns the Object ID.
UINT ObjectType
UINT X
UINT Y
UINT Width
UINT Height
UINT
Simulation macro reference
GLCD Component
This property is of type Panel object and can be referenced with the variable name GLCDComponent.
Selects the GLCD component to display all the objects
Max Objects
This property is of type Unsigned integer and can be referenced with the variable name MaxObjects.
The total number of objects allowed on the screen.
Sets the size of the RAM buffers used to track the various screen elements.
