Component: EtherCAT Slave (EasyCAT) (Comms: IoT/Cloud)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Comms: IoT/Cloud
Image EtherCAT Slave (EasyCAT) component
Provides support for the EtherCAT Slave industrial protocol using an EasyCAT Arduino shield. The shield can be driven from a Flowcode compatible Arduino type board or can be driven using an Arduino using the SCADA Slave firmware to drive EtherCAT from the Flowcode simulation runtime. Compatible with the EasyCAT Easy Configurator tool.
SetInt
Write a 16-bit value to the In receive buffer
BYTE Index
Data Index
UINT Data
MainTask
Must be called as part of the application main program loop.
This macro has no parameters
BYTE
SetLong
Write a 32-bit value to the In receive buffer
BYTE Index
Data Index
ULONG Data
GetFloat
Read a 32-bit floating point value from the Out receive buffer
BYTE Index
Data Index
FLOAT
GetLong
Read a 32-bit value from the Out receive buffer
BYTE Index
Data Index
ULONG
GetInt
Read a 16-bit value from the Out receive buffer
BYTE Index
Data Index
UINT
SetByte
Write an 8-bit value to the In receive buffer
BYTE Index
Data Index
BYTE Data
GetByte
Read a 8-bit value from the Out receive buffer
BYTE Index
Data Index
BYTE
SetFloat
Write a 32-bit floating point value to the In receive buffer
BYTE Index
Data Index
FLOAT Data
Starts up the SPI connection to the EasyCAT board and configures the board.
Returns 1 for a sucessful initialise.
BOOL : Returns true if the operation is a success, else false
Simulation macro reference
Synchronisation Mode
This property is of type Fixed list of ints and can be referenced with the variable name SyncMode.
ASYNC = free running i.e. no synchronization between master and slave (default)
DC_SYNC = interrupt is generated from the distributed clock unit
SM_SYNC = interrupt is generated from the syncronisation manager
Header File
This property is of type Filename and can be referenced with the variable name HeaderFile.
Used to load a header file from Easy CAT Configurator tool to describe the units inputs and outputs
Total Byte Num Out
This property is of type Unsigned integer and can be referenced with the variable name TotalByteNumOut.
Total number of bytes to come out from the EtherCAT master
Total Byte Num In
This property is of type Unsigned integer and can be referenced with the variable name TotalByteNumIn.
Total bytes to come in from the EtherCAT master
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
