Component: Nextion Display (Graphical Color)
Version 1.0 (Release)
Category Graphical Color
Error creating thumbnail: Unable to save thumbnail to destination
Nextion Display component
A simple libray to interface a Nextion display. The elements on the nextion display are built using the Nextion Editor software and uploaded to the display. The component can then interact with the display elements.
Handling Buttons
This example looks for button presses with IDs 1 and 2. On a button release event the corresponding LEDs will be toggled.
FC6 Icon.png Nextion Touch Demo
GetTouchID
Gets the ID of the corresponding touch event.
Must be called after calling GetTouchEvent component macro.
This macro has no parameters
UINT
GetValue
Gets the value from a specific item
<- STRING Name
This parameter may be returned back to the caller
ULONG
SetText
Sets the text of a specific item
<- STRING Name
<- STRING Text
GetText
Gets the text of a specific item
<- STRING Name
STRING
SetFontColour
Sets the foreground font colour of a specific item
<- STRING Name
ULONG Colour
SetPage
Sets the page of the display allowing multiple configurations
<- STRING Name
Name of the page e.g. "page0"
SetValue
Sets the numeric value of a specific item
<- STRING Name
ULONG Number
GetTouchEvent
Collects the next touch event in the queue.
Returns 0 for no touch event detected, 1= touch press, 2 = touch release
BYTE
SetBackgroundColour
Sets the background colour of a specific item
<- STRING Name
ULONG Colour
Sets up the UART connection to the Nextion display
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart1::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart1::BAUD.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart1::TX.
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart1::RX.
Touch Queue Size
This property is of type Unsigned integer and can be referenced with the variable name TouchQueueSize.
Number of touch press/release events we can store before running out of memory.
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name CircularBuffer1::BufferSize.
Sets the number of byte elements inside the circular buffer.
Timeout
This property is of type Unsigned integer and can be referenced with the variable name Timeout.
Time in milliseconds to wait for a reply to a command.
This property is of type True or false and can be referenced with the variable name cal_uart1::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
   Simulation - draws an approximation of the UART data onto the scope trace.
   ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart1::ConsoleData.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart1::DataSource.
Simulation data source used to allow the component to connect to various remote devices
   Nothing - Simulation data is ignored
   COM port - Routes the communication data to and from a physical or virtual COM port
   API - Routes the communication data via a data injector component on the Panel.
