Component: I2S Master/Slave ESP32 (Comms: Interface)
Revision as of 16:13, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray...")
Version 2.0
Category Comms: Interface
I2S Master/Slave ESP32 component
Provides access to the onboard inter-IC sound (I2S) peripheras allowing for simple digital audio input and output.
Stop
Stops the I2S audio stream
Read
Wait timeout ticks to receive length number of samples, returns samples received. 24 and 32-bit data must be split into two integer values per sample.
[[File:]] - Data
Data array to populate with incoming data
- UINT Length
Max number of samples to try and receive
- UINT Timeout
Max number of ticks to wait for incoming samples
CheckQueue
Checks the I2S Event queue for a DMA Buffer full or empty event. For an output returns true when there is an empty DMA buffer available. For an input return true when there is a full DMA buffer available.
[[File:]] - Return
Write
Wait timeout ticks to send length number of samples, returns samples sent 24 and 32-bit data must be split into two integer values per sample.
[[File:]] - Data
Data array containing outgoing data
- UINT Length
Max number of samples to try and send
- UINT Timeout
Max number of ticks to wait for space in the outgoing buffer
Start
Starts the I2S audio stream, auto started by the initialise function.
Configures the I2C peripheral ready for data.
InitRXFilter
Initialization setting for RX Filter
- BYTE Filter
- ULONG Value
GetRxDataCount
Returns the number of valid data bytes in the buffer
- BYTE buffer
The index of the required buffer
Init
Must be called at least once and after every Uninit call to enable the CAN instance
InitTXBuffer
Initialization settings for TX Buffers
- BYTE Buffer
TX Buffer ID = 0,1 or 2
- ULONG ID
CAN Address
- BYTE Length
Number of bytes to send
- STRING Data
Data Array (of Length bytes)
SetRxMaskStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages The messages are accepted if (StdID & Mask) == Filter
- BYTE Mask
Mask number
- BYTE Hi
The high byte (bits 8-15) of the ID
- BYTE Lo
The low byte (bits 0-7) of the ID
SetRxMaskExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages The messages are accepted if (ExtID & Mask) == Filter
- BYTE Mask
Mask 0 or 1
- BYTE ID3
The high byte (bits 24-31) of the ID
- BYTE ID2
The mid-high byte (bits 16-23) of the ID
- BYTE ID1
The mid-low byte (bits 8-15) of the ID
- BYTE ID0
SetValue
Set the Value of the Named property
- STRING Name
- STRING Value
SetRxFilter
Generic function to set Identifier. CAN registers will be configured depending upon Std/Ext mode setting.
- BYTE filter
- ULONG id
SetTxIdent
- BYTE buffer
- ULONG id
CheckRx
Checks to see if any messages are available for 'Buffer' specified
- BYTE Buffer
Send buffer: 0 to 1
InitRXConfig
Initialization setting for RX Buffer Config
- BYTE Buffer
Buffer Number (0 or 1)
- BYTE Value
Config data byte
Uninit
Uninitialises the CAN, freeing its connections for general use
GetList
Get the Filter List of the Named Property
- STRING Name
- STRING Return
GetRxIdent
Generic function to get the received message Identifier.
- BYTE buffer
- ULONG Return
SetRxFilterStd
- BYTE Filter
Filter number
- BYTE Hi
- BYTE Lo
SetRxFilterExd
- BYTE Filter
Send filter: 0 to 3
- BYTE ID3
- BYTE ID2
- BYTE ID1
- BYTE ID0
DAC Channel number
Clock Pin
I2S Clock Pin
Serial Data Pin
I2S Serial Data (SD) Pin
Word Select Pin
I2S Word Select (WS) Pin
Mode
Configures if the I2S peripheral is a master or slave on the bus.
Data Direction
Controls if the I2S data is coming in or out of the microcontroller
Audio Channels
Number of distinct audio channels in the data stream
Sample Rate
Audio sample rate in Hz
Data Bits
Nmber of bits in each audio sample
DMA Buffer Count
I2S DMA Buffer Count
DMA Buffer Size
I2S DMA Buffer Size
Simulations
