Component: FCD helper (Matrix Tools)
Revision as of 16:14, 16 November 2021 by Wiki bot (talk | contribs)
Category Matrix Tools
FCD helper component
A helper control to query the current Flowcode definition XML file.
GetStrListItem
Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added
- STRING Index
- STRING Name
- STRING Return
GetIntListItem
Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added
- UINT Index
- STRING Name
- STRING Return
Register
Registers a property to update when the FCD changes
[[File:]] - Dest
- STRING PropName
- STRING FCDPath
- UINT INdex
A zero based index of the path to find
- STRING IxAttr
- STRING NameAttr
GetPropertyList
Gets a filter list suitable for adding to a property Uses the [u]IxName[/u] as the index into the list Uses the [u]Text[/u] as the line to show in list-boxes
- STRING FCDPath
- UINT Index
- STRING IxName
- STRING Text
- STRING Return
SetMarks
Decides on the presentation of the dial
[[File:]] - Marks
Number of marks on the dial
[[File:]] - Subs
Number of marks before a 'main' mark - can be zero
[[File:]] - ShowNumbers
True to show numbers on the dial, else false
[[File:]] - Return
SetRange
Sets the min-max range to draw on the dial Used for setting the needle
[[File:]] - Start
[[File:]] - End
[[File:]] - Return
SetLabel
Sets the label to draw in the center of the dial
- STRING Hi
- STRING Lo
Label to draw at the bottom
[[File:]] - Return
SetPivotPos
Sets the position of the object the lever rotates around
[[File:]] - PositionHandle
A handle to the position of the depressed location
SetAutoReset
Sets the state of the auto-reset flag If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
[[File:]] - State
Set true to reset to off on sim stop, else false to retain state
SetLatching
Sets whether the button is depressed when the mouse is released
[[File:]] - Enabled
Unregister
Removes the object to the list if present
[[File:]] - Target
SetMovementFor
Sets the movement in units or PI/16 steps for the button
[[File:]] - Target
[[File:]] - Move
Movement to set to, default 4
Simulations
