Component: Base2dChart (Development)
Revision as of 16:52, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Steve Tandy |- | width="20%" style="color:gray;" | Version | 1.1 |- | width="20%" style="color:gra...")
Author Steve Tandy
Version 1.1
Category Development
Base2dChart component
A base component for creating 2d charts.
AddDataXYY1
Adds a data point for a ternary chart (3 axes) to the specified series.
- BYTE Series
Which series to add to (1-8)
[[File:]] - xValue
The value on the first axis
[[File:]] - yValue
The value on the second axis
[[File:]] - zValue
The value on the third axis
AddData
Adds a data point (y-value only) to the specified series.
- BYTE Series
[[File:]] - Value
The data point value
AddDataXY
Adds a data point (x and y values) to the specified series.
- BYTE Series
[[File:]] - xValue
The x coordinate for the data point
[[File:]] - yValue
The y coordinate for the data point
AddCatData
- BYTE Series
- STRING Category
[[File:]] - Value
SetMode
Select the mode of operation
[[File:]] - bUseArrays
True if data points are added to a hidden buffer; False if data is drawn directly onto chart.
ClearData
Removes all datapoints from the chart.
RefreshChart
Redraws the chart.
GetData
Gets a data point from the specified series.
- BYTE Series
[[File:]] - Index
The data point index (1 - 32767)
[[File:]] - Return
AddDataCXYY1
Adds a data point to a bubble chart.
- BYTE Series
- STRING Category
[[File:]] - Y
Y coordinate
[[File:]] - X
X coordinate
[[File:]] - Value
The value of the data point
Categories
Y Values
X Values
Z Values
Title
Style
Stacking
Fill Gradient
Transparency
Data Between Ticks
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Position
Draw Border
Select Series
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
nSeries
dXVal
dYVal
dY1Val
sYCat
bUseArrays
fnAddCatValue
fnClearData
fnAddValueCXYY1
fnAddValueXYY1
fnGetValue
fnGetValueXY
fnRefreshChart
Simulations
