Component: I2C Multiplexer (TCA9548A) (Comms: System)
Revision as of 19:47, 16 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
I2C Multiplexer (TCA9548A) component
An I2C multiplexing IC allowing up to 8 different I2C busses to be connected to a single I2C channel on your target microcontroller.
Here we have a simple example showing how to use the multiplexer to connect multiple of the same I2C sensor IC to the microcontroller.
The multiplexer IC is connected directly to the microcontroller I2C pins and up to 8 temp/humidity sensors are connected to the CH0-CH7 I2C pins of the multiplexer.
I2C Multiplex Example
SelectChannel
Selects a single output channel to multiplex the I2C output to (0-7).
- BYTE Channel
Range: 0-7
SetChannelMask
Allows a user determined number of channels to be connected to the I2C bus.
- BYTE Mask
Range: 0-255 / Bit0=CH0 EN / Bit1 = CH1 EN etc
Startup the I2C bus ready for communications.
Transaction_Read
Attempt to read Length number of bytes from the I2C slave to the given Buffer. Ensure that the Buffer is large enough. Returns number of bytes read, caller should check that this matches requested Length
- BYTE Buffer
Buffer to store the incoming byte data
- UINT Length
Number of bytes to read
Start
Outputs a start condition onto the I²C bus.
Transaction_Initialise
Initialise the I2C interface to communicate with a Slave device at Address Returns 0 on fail, 1 on success
- BYTE Address
7-bit I2C Address without the shift for the R/W bit
Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called.
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor.
Address Bits
Stop Delay
Baud Select
Baud rate to be used
Injector
Channel selection
SDA
SCL
Simulations
Simulate Comms
