Component: Injector (GPS NMEA) ()
Revision as of 19:47, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category
Injector (GPS NMEA) component
Comms data injector to allow simulation of NMEA style GPS messages
GPS Example File GPS Example Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
InitialiseInjector
- STRING InjectorName
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
RxByte
GetConsoleHandle
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
Data Period (ms)
Amount of time in milliseconds to wait between each GPS NMEA packet is sent. Default 1000.
Circular Buffer Size
Max number of bytes the receive queue can hold. Default 1000.
Data Valid
Injected GPS data validity
Altitude
Injected GPS Altitude
Course Over Ground
Injected GPS course over ground (COG)
Dilution Of Precision
Injected GPS dilution of precision (DOP)
Ground Speed
Injected GPS ground speed (Knotts)
HDOP
Injected GPS horizontal dilution of precision (HDOP)
Latitude
Injected GPS lattitude
Longitude
Injected GPS longitude
Number Of Satellites
Injected GPS number of active satellites
VDOP
Injected GPS vertical dilution of precision (VDOP)
Data Source
Injected GPS source for UTC time and date
Simulations
