Component: Humidity (EBM016) (EBM Modules)
| Version | 2.0 |
| Category | EBM Modules |
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
| GetTemperatureReal | |
| Return temperature reading as a float value in degrees C | |
| [[File:]] - | Return |
| GetTemperatureData | |
| Returns the raw register pair value | |
| GetTemperatureInt | |
| Return temperature reading as an integer value in degrees C | |
| GetHumidityInt | |
| returns the relative Humidity reading as an integer value | |
| GetHumidityReal | |
| returns the Humidity reading as a float value | |
| GetHumidityData | |
| Initialises the component ready for I2C communications | |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| SimSetGyro | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
