Component: Temp / Humidity (HTS221) (Environmental)
| Category | Environmental |
Temp / Humidity component
A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 3.5% Temperature Range = -40 - 120 Degrees C +/- 0.5 Degrees C
| ReadHumidityInt | |
| Samples the humidity from the sensor and returns the relative humidity reading as a integer byte from 0 to 100 | |
| ReadTemperatureInt | |
| Samples the temperature from the sensor and returns the reading in degrees C as an integer from -40 to 120. | |
| [[File:]] - | Return |
| ReadHumidityReal | |
| Samples the humidity from the sensor and returns the relative humidity reading as a float from 0.0 to 100.0. | |
| ReadRegister | |
| Reads an 8-bit value from one of the registers onboard the sensor IC. | |
| Address | |
| ReadTemperatureReal | |
| Samples the temperature from the sensor and returns the reading in degrees C as a float from -40.0 to 120.0. | |
| WriteRegister | |
| Writes a value to a register on the sensor IC. | |
| Address | |
| Data | |
| Configures the I2C peripheral ready for communications. | |
| Initialises the component ready for I2C communications | |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| SimSetGyro | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
