Component: Speech (RealSpeak) (Indicators)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Indicators |
Speech (RealSpeak) component
Advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine. Available in simulation only.
|   | GetTag |
| Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long. | |
|  - BYTE | Data |
|  - VOID | Return |
|   | IsKnownID |
| Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory. | |
| [[File:]] - | Return |
|   | Initialise |
| Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored. | |
|  - VOID | Return |
|   | Properties |
|   | Voice |
| RealSpeak selected voice - Download and install RealSpeak voices for more options. | |
|   | Rate |
| Voice speech rate - Default 1 - Range (0-100) | |
|   | Connections |
|   | Simulations |
