| Author
Matrix Ltd
| Version
1.1
| Category
Brushless Motor (Standard) component
A small brushless motor component designed to be driven from a three phase ESC. The ESC would be driven using the Servo Motor Controller component.
3 x 4 Keypad Schematic
Example schematic of a 3 x 4 Keypad.
Multi Digit Number Entry
A simple example to take in a decimal number (0-65535) from the user and then use this number as a delay for flashing a LED on and off. Shows the principals of reading the keypad and building up a multi-digit number.
Keypad Delay
Keypad Based Door Entry System
Each key press on the keypad is fed into the Circular Buffer component. We then poll the buffer to see if the correct characters for the password have been entered.
Keypad Door Entry
If the correct sequence is detected then we activate the solenoid component for 5 seconds.
FT_Write
| Write data to the device.
| [[File:]] -
Handle
| Handle of the device.
- BYTE
Buffer
| Pointer to the buffer that contains the data to be written to the device.
- ULONG
Bytes
| Number of bytes to write to the device.
- ULONG
Count
| Pointer to a variable of type DWORD which receives the number of bytes written to the device.
- BYTE
FT_Read
| Read data from the device.
| [[File:]] -
Handle
- BYTE
Buffer
| Pointer to the buffer that receives the data from the device.
- ULONG
Bytes
| Number of bytes to be read from the device.
- ULONG
Count
| Pointer to a variable of type DWORD which receives the number of bytes read from the device.
- BYTE
FT_SetFlowControl
| This function sets the flow control for the device.
| [[File:]] -
Handle
- UINT
FlowControl
| Flow setting 0=None, 0x0100=RTS/CTS, 0x0200=DTR/DSR, 0x0400=XON/XOFF
- BYTE
Xon
| Character used to signal Xon. Only used if flow control is Xon/Xoff
- BYTE
Xoff
| Character used to signal Xoff. Only used if flow control is Xon/Xoff
- BYTE
FT_GetModemStatus
| Gets the modem status and line status from the device.
| [[File:]] -
Handle
| [[File:]] -
ModemStatus
| Pointer to a variable of type DWORD which receives the modem status and line status from the device.
- BYTE
FT_SetBreakOn
| Sets the BREAK condition for the device.
| [[File:]] -
Handle
- BYTE
FT_CreateDeviceInfoList
| This function builds a device information list and returns the number of D2XX devices connected to the system. The list contains information about both unopen and open devices.
| [[File:]] -
DevCount
| Unsigned long array used to store the number of devices connected
- BYTE
FT_SetTimeouts
| This function sets the read and write timeouts for the device.
| [[File:]] -
Handle
| [[File:]] -
ReadTimeout
| Read timeout in milliseconds.
| [[File:]] -
WriteTimeout
| Write timeout in milliseconds.
- BYTE
FT_SetBitMode
| Enables different chip modes.
| [[File:]] -
Handle
- BYTE
Mask
| Required value for bit mode mask. This sets up which bits are inputs and outputs. A bit value of 0 sets the corresponding pin to an input, a bit value of 1 sets the corresponding pin to an output.
- BYTE
Mode
| 0=Reset / 1=AsyncBB / 2=MPSSE / 4=SyncBB / 8=MCUHost / 16=FastOpto / 32=CBUS / 64=SyncFIFO
- BYTE
FT_SetRts
| This function sets the Request To Send (RTS) control signal.
| [[File:]] -
Handle
- BYTE
FT_GetDeviceInfoDetail
| This function returns an entry from the device information list.
- ULONG
Index
| Index of the entry in the device info list.
- ULONG
Flags
| Pointer to unsigned long to store the flag value.
- ULONG
Type
| Pointer to unsigned long to store device type.
- ULONG
ID
| Pointer to unsigned long to store device ID.
- ULONG
LocID
| Pointer to unsigned long to store the device location ID.
- BYTE
SerNum
| Pointer to buffer to store device serial number as a null terminated string
- BYTE
Descript
| Pointer to buffer to store device description as a null-terminated string
| [[File:]] -
TempHandle
| Pointer to a variable of type FT_HANDLE where the handle will be stored
- BYTE
FT_Close
| Close an open device.
| [[File:]] -
Handle
- BYTE
FT_ClrDtr
| This function clears the Data Terminal Ready (DTR) control signal.
| [[File:]] -
Handle
- BYTE
FT_Purge
| This function purges receive and transmit buffers in the device.
| [[File:]] -
Handle
| [[File:]] -
Mask
| Used to determine which buffer to purge, 1=Rx / 2=Tx / 3=Both
- BYTE
FT_GetQueueStatus
| Gets the number of bytes in the receive queue.
| [[File:]] -
Handle
| [[File:]] -
RxQueueLength
| Pointer to a variable of type DWORD which receives the number of bytes in the receive queue.
- BYTE
FT_SetDataCharacteristics
| This function sets the data characteristics for the device.
| [[File:]] -
Handle
- BYTE
WordLength
| Number of bits per word - Must be 7 or 8
- BYTE
StopBits
| Number of stop bits - Must be 1 or 2
- BYTE
Parity
| Parity 0=None / 1=Odd / 2=Even / 3=Mark / 4=Space
- BYTE
FT_SetBreakOff
| Resets the BREAK condition for the device.
| [[File:]] -
Handle
- BYTE
FT_SetDivisor
| This function sets the baud rate for the device. It is used to set non-standard baud rates.
| [[File:]] -
Handle
- UINT
Divisor
| Divisor.
- BYTE
FT_SetBaudRate
| [[File:]] -
Handle
- ULONG
BaudRate
| Baud rate.
- BYTE
FT_SetDtr
| This function sets the Data Terminal Ready (DTR) control signal.
| [[File:]] -
Handle
- BYTE
FT_Open
| Open the device and return a handle which will be used for subsequent accesses.
| [[File:]] -
Device
| Index of the device to open. Indices are 0 based.
| [[File:]] -
ft_Handle
| Pointer to a variable of type FT_HANDLE where the handle will be stored. This handle must be used to access the device.
- BYTE
ScanFor232
| Scans for a FTDI D2XX device, returnes true if at least one device was found.
| [[File:]] -
FT_ResetDevice
| This function sends a reset command to the device.
| [[File:]] -
Handle
- BYTE
FT_SetChars
| This function sets the special characters for the device.
| [[File:]] -
Handle
- BYTE
EventCh
| Event character.
- BYTE
EventChEn
| 0 if event character disabled, non-zero otherwise.
- BYTE
ErrorCh
| Error character.
- BYTE
ErrorChEn
| 0 if error character disabled, non-zero otherwise.
- BYTE
ESC Type
| Selects if the ESC is capable of operating the motor in one or two directions. A R/C car ESC would likely be Bi-Directional whereas a helicopter ESC would be Uni-Directional.
Link To...
| Select a panel object here to connect it 'mechanically' to the servo's actuator. The selected object will now be moved whenever the servo position changes. NB) To move multiple objects, first group the objects, and then select the group.
Reverse Output
| Some manufacturers motors may rotate in different ways to others. Changing this property allows you to flip the direction of the simulated motor to better match with the real world hardware.
Simulations
