Component: Quadrature Encoder (General Input)
Author | Matrix TSL |
Version | 1.4 |
Category | General Input |
Quadrature Encoder component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Polling
Example program showing how to use a quadrature encoder component using a polling method. Quad_Encoder_Test
Timer Interrupt Based Polling
Example program showing how to use a quadrature encoder component using a polling method via a timer interrupt. Quad_Encoder_Timer
Interrupt On Change
Example program showing how to use a quadrature encoder component using a interrupt on pin state change interrupt (IOC). Quad_Encoder_IOC
CheckForChanges | |
Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error | |
- BYTE | Return |
Disable | |
Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
- VOID | Return |
WriteCounter32 | |
Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
[[File:]] - | Value |
- VOID | Return |
Enable | |
Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
- VOID | Return |
ReadCounter | |
Reads the current dial counter This is a counter from -32768 to 32767 | |
[[File:]] - | Return |
WriteCounter | |
Sets the value of the internal count variable. Range: -32768 to 32767 | |
- VOID | Return |
ResetCounter | |
Resets the current dial counter to zero | |
- VOID | Return |
ReadCounter32 | |
Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
SpinRight | |
Spins the formula flowcode on the spot in a clockwise direction as seen from above. | |
- BYTE | Power |
- VOID | Return |
CheckIR | |
Checks to see if a IR sensor is within the master threshold distance. | |
- BYTE | Sensor |
- BYTE | Return |
ReadIRSensor | |
Reads the analogue value from the specified IR distance sensor. | |
- BYTE | Sensor |
- UINT | Return |
SetMotors | |
Sets the speed and direction of the Formula Flowcode motors. | |
[[File:]] - | Left_Power |
Valid Range = -255 to 255 | |
[[File:]] - | Right_Power |
- VOID | Return |
Reverse | |
Drives both motors of the formula flowcode backwards with the power specified. | |
- BYTE | Power |
- VOID | Return |
WaitForSwitch | |
Waits for the specified switch to be pressed. | |
- BYTE | Switch |
- VOID | Return |
ReadLDR | |
Reads the current audio signal level from the on-board light sensor. | |
WriteLEDs | |
Allows control of all 8-LEDs on the front of the Formula Flowcode. | |
- BYTE | LED_Byte |
- VOID | Return |
Initialise | |
Starts up the formula flowcode PWM for motor control and performs the wait for button press | |
- VOID | Return |
