Component: Buzzer (Audio Output)
| Category | Audio Output |
Buzzer component
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation. To actually drive a buzzer you would have to amplify the signal from the microcontroller using a transistor or MOSFET.
Depending on your Buzzer you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
| BuzzerOff | |
| Switch Off the Buzzer | |
| BuzzerOn | |
| Switch On the Buzzer | |
| BuzzerOnDelay | |
| Switch the Buzzer on for a fixed amount of time | |
| Time | |
| Time in milliseconds to keep the buzzer on | |
| WriteLEDs | |
| Allows control of all 8-LEDs on the front of the Formula Flowcode. | |
| LED_Byte | |
| Starts up the formula flowcode PWM for motor control and performs the wait for button press | |
