| Author
Matrix TSL
| Version
1.0
| Category
Audio Output
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Here is a simple example that will create a siren effect using a piezo sounder.
Piezo Siren
Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
BuzzerBeep
| Switches the buzzer on and off automatically to allow for a series of beeps
- UINT
OnTime
| Length of time in ms the buzzer will remain on
- UINT
OffTime
| Length of time in ms the buzzer will remain off
- BYTE
NumberLoops
| Number of times to repeat the sequence. Range 1-255
- UINT
Frequency
| frequency in hz to output to the Piezo sounder
BuzzerOnDelay
| Switch the Buzzer on for a fixed amount of time
- UINT
Time
| Time in milliseconds to keep the buzzer on
- UINT
Frequency
| Frequency to output in Hz
SetAddress
| Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules.
- BYTE
Address
| Range: 0x40 - 0x7F
SetClockFrequency
| Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty.
- ULONG
Clock
GetClockFrequency
| Returns the current clock frequency
- ULONG
WriteMicroseconds
| Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
- BYTE
Output
| One of the PWM output pins - Range: 0 to 15
- UINT
Microseconds
| The number of Microseconds to turn the PWM output ON
SetPWM
- BYTE
Output
- UINT
On
| At what point in the 4096-part cycle to turn the PWM output ON
- UINT
Off
| At what point in the 4096-part cycle to turn the PWM output OFF
| Sets up the I2C ready for communications to begin
WakeUp
| Wakes the module from Sleep mode
SetPin
| Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
- BYTE
Output
- UINT
Duty
| The number of ticks out of 4096 to be active
| [[File:]] -
Invert
| 0=Normal, 1=Inverted
DrawRectangle2D
| Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
| [[File:]] -
X
| Number of pixels to shift the display -1 to 1 / 0 = No Shift
| [[File:]] -
Y
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
GetLEDIndex3D
| Gets the index of a single LED in RAM as a 3D array.
- UINT
X
| LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
| LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
Z
| LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
| Start X pixel coordinate
- BYTE
Y1
| Start Y pixel coordinate
- BYTE
Z1
| Start Z pixel coordinate
- BYTE
X2
| End X pixel coordinate
- BYTE
Y2
| End Y pixel coordinate
- BYTE
Z2
| End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
| Red Colour Channel
- BYTE
G
| Green Colour Channel
- BYTE
B
| White Colour Channel
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
| [[File:]] -
X
| [[File:]] -
Y
| [[File:]] -
Z
- BYTE
DataMode
| Sets up the data memory and draws the simulated LED cube on the panel.
Output Pin
| Pin used to drive the output to the buzzer
Color
| Controls the color of the Buzzer object on the panel.
Simulations
