Component: RGB LED APA102C (LEDs)
Revision as of 21:08, 16 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category LEDs
RGB LED APA102C component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
Fc9-comp-macro.png SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
[[File:]] - Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
Fc9-comp-macro.png GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
Fc9-u16-icon.png - UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
Fc9-u8-icon.png - BYTE ColIdx
0 = R, 1 = G, 2 = B
Fc9-comp-macro.png SetBrightnessByte
Fc9-u8-icon.png - BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
Fc9-comp-macro.png DrawLine2D
Draws a line on a 2D array of LEDs
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-comp-macro.png SetLEDColour
Fc9-comp-macro.png SetAllLEDColour
Sets the colour of all the LEDs in RAM
Fc9-comp-macro.png Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
Fc9-comp-macro.png ShiftLEDs1D
Shifts the LED colours in 1D and wraps
Fc9-u8-icon.png - BYTE Direction
0 = Forwards, 1 = Backwards
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
Fc9-comp-macro.png DrawLine3D
Draws a line on a 3D array of LEDs
Fc9-u16-icon.png - UINT Z1
Fc9-u16-icon.png - UINT Z2
Fc9-comp-macro.png GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
LED Column to change the colour / Range: 0 to (LED Column - 1)
LED Row to change the colour / Range: 0 to (LED Row - 1)
Fc9-comp-macro.png DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-comp-macro.png ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
[[File:]] - X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
[[File:]] - Y
Fc9-comp-macro.png GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Fc9-comp-macro.png DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
Fc9-u8-icon.png - BYTE Z1
Fc9-u8-icon.png - BYTE Z2
Fc9-comp-macro.png Initialise
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
Fc9-comp-macro.png ShiftLEDs3D
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Sets up the data memory and draws the simulated LED cube on the panel.
Fc9-type-16-icon.png LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
Fc9-type-21-icon.png LED Count
Total number of LEDs in the design
Fc9-type-21-icon.png LED Columns
Number of horizontal LEDs - X axis
Fc9-type-15-icon.png Column Spacing
X Spacing Between LEDs on the Panel
Fc9-type-21-icon.png LED Rows
Number of vertical LEDs - Y axis
Fc9-type-15-icon.png Row Spacing
Y Spacing Between LEDs on the Panel
Fc9-type-21-icon.png LED Layers
Number of LED layers - Z axis
Fc9-type-15-icon.png Layer Spacing
Z Spacing Between LEDs on the Panel
Fc9-type-7-icon.png Flip X
Flips the X axis if the LEDs are wired from the right hand side of the display.
Fc9-type-7-icon.png Flip Y
Flips the Y axis if the LEDs are wired from the bottom side of the display.
Fc9-type-7-icon.png Flip Z
Flips the Z axis if the LEDs are wired from the upper most side of the display.
Fc9-type-16-icon.png LED Current Usage
Fc9-type-5-icon.png Data Pin
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
Fc9-type-5-icon.png Clock Pin
LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png Output Mode
Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
