| Author
Matrix TSL
| Version
1.0
| Category
General Output
PWM 16CH 12Bit (PCA9685) component
The PCA9685 is an I²C-bus controlled 16-channel LED controller optimized for Red/Green/Blue/Amber (RGBA) color backlighting or Servo motor applications. Each output has its own 12-bit resolution (4096 steps) fixed frequency individual PWM controller that operates at a programmable frequency from a typical of 24 Hz to 1526 Hz. All outputs are set to the same PWM frequency. Up to 64 devices can be chained together on a single I²C-bus to provide up to 1024 individual PWM outputs.
Reset
| Sends a reset command to the PCA9685 chip over I2C
SetPWMFrequency
| Sets the PWM frequency for the entire chip, up to approx 1.6 KHz
| [[File:]] -
Frequency
| Floating point frequency that we will attempt to match
SetOutputMode
| Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode.
| [[File:]] -
Mode
| 0=OpenDrain, 1=Push/Pull
Sleep
| Puts the module into Sleep mode
SetExternalClock
| Sets EXTCLK pin to use the external clock
- BYTE
Prescale
| External Clock Prescaler - Range: 3-255
SetAddress
| Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules.
- BYTE
Address
| Range: 0x40 - 0x7F
SetClockFrequency
| Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty.
- ULONG
Clock
GetClockFrequency
| Returns the current clock frequency
- ULONG
WriteMicroseconds
| Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
- BYTE
Output
| One of the PWM output pins - Range: 0 to 15
- UINT
Microseconds
| The number of Microseconds to turn the PWM output ON
SetPWM
- BYTE
Output
- UINT
On
| At what point in the 4096-part cycle to turn the PWM output ON
- UINT
Off
| At what point in the 4096-part cycle to turn the PWM output OFF
| Sets up the I2C ready for communications to begin
WakeUp
| Wakes the module from Sleep mode
SetPin
| Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
- BYTE
Output
- UINT
Duty
| The number of ticks out of 4096 to be active
| [[File:]] -
Invert
| 0=Normal, 1=Inverted
DrawRectangle2D
| Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
| [[File:]] -
X
| Number of pixels to shift the display -1 to 1 / 0 = No Shift
| [[File:]] -
Y
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
GetLEDIndex3D
| Gets the index of a single LED in RAM as a 3D array.
- UINT
X
| LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
| LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
Z
| LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
| Start X pixel coordinate
- BYTE
Y1
| Start Y pixel coordinate
- BYTE
Z1
| Start Z pixel coordinate
- BYTE
X2
| End X pixel coordinate
- BYTE
Y2
| End Y pixel coordinate
- BYTE
Z2
| End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
| Red Colour Channel
- BYTE
G
| Green Colour Channel
- BYTE
B
| White Colour Channel
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
| [[File:]] -
X
| [[File:]] -
Y
| [[File:]] -
Z
- BYTE
DataMode
| Sets up the data memory and draws the simulated LED cube on the panel.
Address
| Module I2C Address. This setting can be overridden using the SetAddress component macro.
Output Mode
| Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode. Can be overridden using the SetOutputMode component macro.
Clock Type
| Configures the input clock source to the module.
Clock Frequency
| Frequency of the module. Internal oscillator defaults to 250000000 or 25MHz but can actually be anywhere from 23 to 27MHz. External clock frequency can be specified here up to a max value of 50000000 or 50MHz. This setting can be overridden using the SetClockFrequency component macro.
Prescaler
| External Clock Prescaler Range: 3 to 255
Target PWM Frequency
| The ideal PWM frequency we would like to generate on the output pins. Servo motors require an output frequency around 50Hz. LEDs require a mugh higher output frequency to avoid visible flicker.
Actual PWM Frequency
| The calculated actual PWM frequency available using the Clock Frequency and Prescaler
PWM Resolution
| Number of microseconds the PWM output can resolve to
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Stop Delay
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the API component on the panel to interact with to provide comms simulation.
Simulations
Simulate Comms
