Component: Base2dObject (Development)
Jump to navigationJump to search| Author | Steve Tandy |
| Category | Development |
Base2dObject component
| GetValue | |
| Returns the current value of the component. | |
| [[File:]] - | Return |
| SetValue | |
| Sets the component to the specified value. | |
| [[File:]] - | value |
| A new value for the component. | |
| SetMode | |
| Select the mode of operation | |
| [[File:]] - | bUseArrays |
| True if data points are added to a hidden buffer; False if data is drawn directly onto chart. | |
| ClearData | |
| Removes all datapoints from the chart. | |
| SetValue | |
| RefreshChart | |
| Redraws the chart. | |
| GetData | |
| Gets a data point from the specified series. | |
| Series | |
| Which series to add to (1-8) | |
| [[File:]] - | Index |
| The data point index (1 - 32767) | |
| GetList | |
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
| Name | |
| InitRXConfig | |
| Initialization setting for RX Buffer Config | |
| Buffer | |
| Buffer Number (0 or 1) | |
| Value | |
| Config data byte | |
| Uninit | |
| Uninitialises the CAN, freeing its connections for general use | |
| GetList | |
| Get the Filter List of the Named Property | |
| Name | |
| GetRxIdent | |
| Generic function to get the received message Identifier. | |
| buffer | |
| Properties | |
| Value | |
| Connections | |
| Simulations | |
