Component: Data Sheet B (Charts)
Jump to navigationJump to search| Author | Steve Tandy |
| Category | Charts |
Data Sheet B component
A component that accepts data (using series) that can then be viewed in a spreadsheet.
| Clear | |
| Resets the XY chart and removes all data points. | |
| AddData | |
| Add data to a spreadsheet. Returns true if ok. | |
| series | |
| column for the data (1 - 8) | |
| [[File:]] - | data |
| the value to store in the spreadsheet | |
| [[File:]] - | Return |
| GetData | |
| Returns the data from a spreadsheet row-column reference. | |
| [[File:]] - | row |
| row for the data (1 - 32767) | |
| [[File:]] - | column |
| column for the data (1 - 255) | |
| SetValue | |
| Sets the component to the specified value. | |
| [[File:]] - | value |
| A new value for the component. | |
| RefreshChart | |
| Redraws the chart. | |
| GetData | |
| Gets a data point from the specified series. | |
| Series | |
| Which series to add to (1-8) | |
| [[File:]] - | Index |
| The data point index (1 - 32767) | |
| GetList | |
| Returns CHANNEL or PRESCALE list from the FCD and updates the internal property | |
| Name | |
| InitRXConfig | |
| Initialization setting for RX Buffer Config | |
| Buffer | |
| Buffer Number (0 or 1) | |
| Value | |
| Config data byte | |
| Uninit | |
| Uninitialises the CAN, freeing its connections for general use | |
| GetList | |
| Get the Filter List of the Named Property | |
| Name | |
| GetRxIdent | |
| Generic function to get the received message Identifier. | |
| buffer | |
| Properties | |
| Connections | |
| Simulations |
