Component: Numeric Indicator (Indicators)
Revision as of 10:34, 17 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Steve Tandy |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gra...")
Author Steve Tandy
Category Indicators
Numeric Indicator component
A 2d numeric indicator component.
GetValue
Returns the current value of the component.
[[File:]] - Return
SetValue
Sets the component to the specified value.
[[File:]] - value
A new value for the component.
SetValue
[[File:]] - value
Slave_Init
Initialise the Slave
Master_Disable_CS
Outputs a high signal to the chip select pin to deselect the remote slave device.
Master_Uninit
Uninitialise the Master
Master_Byte
Sends and receives a data byte
- BYTE DataOut
GetConsoleHandle
Returns a handle to the console used by this component
[[File:]] - Return
Slave_TxByte
Sets the data to be transmitted to the SPI master.
- BYTE Data
Slave_RxByte
Returns the data received from the SPI Master
SetValue
Change Named property to new Value.
- STRING Name
- STRING Value
SetPrescaler
Sets the prescaler value for the clock divider chain
- BYTE Prescaler
Master_Init
Initialise the Master
GetList
returns Named property list
- STRING Name
- STRING Return
Value
Style
Type
Cell Count
Show Decimal Point
Show Leading Zeros
Show Sign
Decimal Places
Simulations
