Component: I2C Slave (Comms: Interface)
| Author | Matrix Ltd. |
| Version | 1.3 |
I2C Slave component
PIC16F1937 Examples
The slave device is connected to a bank of switches, the master device to a bank of LEDs. The value of the switches is passed to the master LEDs.
Master Read Example
Slave Switches Example
The slave device is connected to a bank of LEDs, the master device to a bank of switches. The value of the switches is passed to the slave LEDs.
Master Send Example
Arduino Uno Examples
Example program showing how to use the I2C Slave on an AVR Arduino device.
I2C Slave Arduino Uno Example
ECIO40P Examples
Example program showing how to use the I2C Slave on an ECIO40P device.
Master Example
| Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called. | |
| Startup the I2C bus ready for communications. | |
| Start | |
| Outputs a start condition onto the I²C bus. | |
| GetInt | |
| Gets an integer from the LUT | |
| Index | |
| SetFloatBits | |
| Sets the size of a float LUT entry | |
| Bits | |
| AddInt | |
| Int to add to the int array | |
| Value | |
| AddFloat | |
| Add a float to the floating point LUT | |
| [[File:]] - | Value |
| Floating point values | |
| Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail. | |
| SampleAccel | |
| Samples the accelerometer 0 = no new data, 1 = new data available | |
| Left | |
| Rotates the robot left - waits for the angle to be traversed before returning | |
| Angle | |
| Angle to turn in degrees | |
| LCDDrawPixel | |
| Allows a single pixel on the LCD to be set or cleared | |
| X | |
| X Pixel 0-127 | |
| Y | |
| Y Pixel 0-31 | |
| State | |
| 0=White (Off), 1=Black (On) | |
| ServoSetPosition | |
| Allows one of the servo positions to be assigned | |
| Channel | |
| Range 0-3 | |
| Position | |
| Range 0-255 | |
| CardBitmap | |
| Displays a monochrome bitmap read from the card on the LCD | |
| X | |
| Range 0-127 | |
| Y | |
| Range 0-31 | |
| Filename | |
| CardOpen | |
| Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
| Filename | |
| Forwards | |
| Drives the robot forwards - waits for the distance to be traversed before returning | |
| Distance | |
| Distance in mm | |
| ReadBearing | |
| Reads the compass bearing based on the degrees clockwise from magnetic north. | |
| [[File:]] - | Return |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| LCDDrawLine | |
| Allows a single pixel width line to be drawn on the LCD | |
| X1 | |
| X Pixel 0-127 | |
| Y1 | |
| Y Pixel 0-31 | |
| X2 | |
| X Pixel 0-127 | |
| Y2 | |
| Y Pixel 0-31 | |
| ServoAutoMoveToPosition | |
| Allows one of the servo positions to move gradually to a new position | |
| Channel | |
| Range 0-3 | |
| Position | |
| Range 0-255 | |
| ReadAllValue | |
| Reads a single value stored from the read all command Index dictates which sensor value to read | |
| Index | |
| 0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
| LCDBacklight | |
| Allows the LCD backlight brighntess to be adjusted | |
| Intensity | |
| Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
| LCDDrawRect | |
| Allows a rectangle to be drawn on the LCD | |
| X1 | |
| X Pixel 0-127 | |
| Y1 | |
| Y Pixel 0-31 | |
| X2 | |
| X Pixel 0-127 | |
| Y2 | |
| Y Pixel 0-31 | |
| ReadLine | |
| Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
| index | |
| 0=Left, 1=Right | |
| ServoDisable | |
| Allows one of the servo outputs 0-3 to be disabled | |
| Channel | |
| Range 0-3 | |
| ServoEnable | |
| Allows one of the servo outputs 0-3 to be enabled | |
| Channel | |
| Range 0-3 | |
| CardReadByte | |
| Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
| CardErase | |
| Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
| Filename | |
| CardWriteByte | |
| Appends a byte to the end of the currently open file | |
| Data | |
| EncoderRead | |
| Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
| index | |
| 0=Left, 1=Right | |
| SetMotors | |
| Sets the motor speeds without feedback Range -100 to 100 | |
| [[File:]] - | Left |
| [[File:]] - | Right |
| Backwards | |
| Drives the robot backwards - waits for the distance to be traversed before returning | |
| Distance | |
| Distance in mm | |
| EncoderReset | |
| Resets the motor encoder counters | |
| LCDVerbose | |
| Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
| State | |
| 0=Off 1=On | |
| SetProp | |
| Allows the COM port property to be set from a parent component. | |
| PropName | |
| PropVal | |
| CardInit | |
| Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
| GetProp | |
| Allows the property filter for the COM port list to be copied to a parent component. | |
| PropName | |
| LCDClear | |
| Clears the LCD | |
