Component: BBC Weather Observation (Comms: IoT/Cloud)
Revision as of 10:36, 17 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: IoT/Cloud
BBC Weather Observation component
Easily allows you to collect observed weather metrics for your area using the BBC Weather data service. Supports temperature and humidty for your selected area. Also available are Wind Direction, Wind Speed and Air Pressure but please note these are not always available depending on your selected area.
Here is a basic example to read the observation data and report the information on a graphical display.
BBCWeatherDemo
The location can be set by adjusting the BBC Weather location property, see the component property tooltips for more information on how to do this.
On an embedded device you would need a TCP/IP component to allow the communications to the BBC server. This then links to the Network Comms component.
GetWindDirection
Reads the reported wind direction as a string. Please note this data may not be available for your selected location.
- STRING Return
RequestData
Requests data about your selected location from the BBC weather service. Returns true if the request was successful. Must be called before trying to call any of the GetXXX macros.
[[File:]] - Return
GetHumidity
Reads the reported humidity in Relative Humdity.
GetTemperature
Reads the reported temperature in the selected scale.
[[File:]] - Scale
0 = Celcius, 1 = Farenheit
[[File:]] - Return
GetWindSpeed
Reads the reported wind speed in MPH. Please note this data may not be available for your selected location.
SetLocationCode
Allows the location code to be altered from the default location code set in the component properties. After changing the location the RequestData macro must be called to refresh the forecast variables.
- STRING NewLocation
New location string, see Location property tooltip for more info.
GetPressure
Reads the reported air pressure in milli bar (mb). Please note this data may not be available for your selected location.
GetLocationName
Reads the reported location name as a string.
- STRING Return
Sets up the component ready to collect weather data.
SetLocationCode
GetSunrise
Reads the forecast sunrise time as a string for the selected day.
- STRING Return
GetPressure
Reads the forecast air pressure in milli bar (mb) for the selected day.
SetForecastDay
Chooses which day of the three day forecast to look at.
- BYTE Day
0 = Today, 1 = Tomorrow, 2 = Day After Tomorrow
GetUVRisk
Reads the forecast UV Risk for the selected day.
GetLocationName
- STRING Return
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Left
Rotates the robot left - waits for the angle to be traversed before returning
- UINT Angle
Angle to turn in degrees
ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
- BYTE index
LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
- BYTE X
X Pixel 0-127
- BYTE Y
Y Pixel 0-31
- BYTE State
0=White (Off), 1=Black (On)
ServoSetPosition
Allows one of the servo positions to be assigned
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
CardBitmap
Displays a monochrome bitmap read from the card on the LCD
- BYTE X
Range 0-127
- BYTE Y
Range 0-31
- STRING Filename
CardRecordMic
Records an audio stream on the card from the microphone
- BYTE BitDepth
0=8-bit, 1=16-bit
- BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
- UINT RecordTime
Time to record for in seconds, Range 0-65535
- STRING Filename
CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
- STRING Filename
Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
GetConsoleHandle
[[File:]] - Return
LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
- BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
LCDBacklight
Allows the LCD backlight brighntess to be adjusted
- BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDDrawRect
Allows a rectangle to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
- BYTE index
0=Left, 1=Right
ServoDisable
Allows one of the servo outputs 0-3 to be disabled
- BYTE Channel
Range 0-3
ServoEnable
Allows one of the servo outputs 0-3 to be enabled
- BYTE Channel
Range 0-3
CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
- STRING Filename
CardWriteByte
Appends a byte to the end of the currently open file
- BYTE Data
EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
- BYTE index
0=Left, 1=Right
SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
EncoderReset
Resets the motor encoder counters
LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
- BYTE State
0=Off 1=On
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
Network Comms Component
Network Communications component to use as the bridge to the TCP/IP network.
BBC IP Address
IP Address linked to the following URL: weather-broker-cdn.api.bbci.co.uk
Location Code
BBC code for your area. In a web browser go to www.bbc.co.uk/weather/ Then type in your city in the search bar and your code will be shown at the end of the URL. For example Manchester in the UK = 2643123 In the UK you can also use the first half of your post code, e.g. HX1
Receive Timeout
Maximum time to wait for valid incoming data.
Simulations
