Component: EtherCAT Slave (EasyCAT) (Comms: IoT/Cloud)
Revision as of 10:36, 17 November 2021 by Wiki bot (talk | contribs)
Category Comms: IoT/Cloud
EtherCAT Slave (EasyCAT) component
Provides support for the EtherCAT Slave industrial protocol using an EasyCAT Arduino shield. The shield can be driven from a Flowcode compatible Arduino type board or can be driven using an Arduino using the SCADA Slave firmware to drive EtherCAT from the Flowcode simulation runtime. Compatible with the EasyCAT Easy Configurator tool.
SetInt
Write a 16-bit value to the In receive buffer
- BYTE Index
Data Index
- UINT Data
MainTask
Must be called as part of the application main program loop.
SetLong
Write a 32-bit value to the In receive buffer
- BYTE Index
Data Index
- ULONG Data
GetFloat
Read a 32-bit floating point value from the Out receive buffer
- BYTE Index
Data Index
[[File:]] - Return
GetLong
Read a 32-bit value from the Out receive buffer
- BYTE Index
Data Index
- ULONG Return
GetInt
Read a 16-bit value from the Out receive buffer
- BYTE Index
Data Index
SetByte
Write an 8-bit value to the In receive buffer
- BYTE Index
Data Index
- BYTE Data
GetByte
Read a 8-bit value from the Out receive buffer
- BYTE Index
Data Index
SetFloat
Write a 32-bit floating point value to the In receive buffer
- BYTE Index
Data Index
[[File:]] - Data
Starts up the SPI connection to the EasyCAT board and configures the board. Returns 1 for a sucessful initialise.
[[File:]] - Return
Sets up the component ready to collect weather data.
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Left
Rotates the robot left - waits for the angle to be traversed before returning
- UINT Angle
Angle to turn in degrees
ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
- BYTE index
LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
- BYTE X
X Pixel 0-127
- BYTE Y
Y Pixel 0-31
- BYTE State
0=White (Off), 1=Black (On)
ServoSetPosition
Allows one of the servo positions to be assigned
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
CardBitmap
Displays a monochrome bitmap read from the card on the LCD
- BYTE X
Range 0-127
- BYTE Y
Range 0-31
- STRING Filename
CardRecordMic
Records an audio stream on the card from the microphone
- BYTE BitDepth
0=8-bit, 1=16-bit
- BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
- UINT RecordTime
Time to record for in seconds, Range 0-65535
- STRING Filename
CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
- STRING Filename
Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
GetConsoleHandle
[[File:]] - Return
LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
- BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
LCDBacklight
Allows the LCD backlight brighntess to be adjusted
- BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDDrawRect
Allows a rectangle to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
- BYTE index
0=Left, 1=Right
ServoDisable
Allows one of the servo outputs 0-3 to be disabled
- BYTE Channel
Range 0-3
ServoEnable
Allows one of the servo outputs 0-3 to be enabled
- BYTE Channel
Range 0-3
CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
- STRING Filename
CardWriteByte
Appends a byte to the end of the currently open file
- BYTE Data
EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
- BYTE index
0=Left, 1=Right
SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
EncoderReset
Resets the motor encoder counters
LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
- BYTE State
0=Off 1=On
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
Synchronisation Mode
ASYNC = free running i.e. no synchronization between master and slave (default) DC_SYNC = interrupt is generated from the distributed clock unit SM_SYNC = interrupt is generated from the syncronisation manager
Header File
Used to load a header file from Easy CAT Configurator tool to describe the units inputs and outputs
Total Byte Num Out
Total number of bytes to come out from the EtherCAT master
Total Byte Num In
Total bytes to come in from the EtherCAT master
SPI Channel selector
MOSI
MISO
CLK
CS / SS
Prescale
Prescale option selector
Simulations
Simulation Comms
API
