Component: MIDI (Comms: System)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Comms: System
MIDI component
Low level routines for controlling or interacting with a standard MIDI interface.
Basic example to play a series of notes getting higher in pitch and then going down in pitch. This repeats in a loop and each time the loop repeats the instrument is changed. The current note and instrument are displayed on the LCD. MIDI Test File
The MIDI component during simulation has functionality to allow it to work with MIDI synthesizers installed on your PC.
To select your software or hardware synthesizer select from the property selector.
If you don't have a MIDI interface installed then IP MIDI seems to be a good option that works well.
Once installed the MIDI output should play through your computer speakers.
The console window can be used to view the MIDI data as it is sent out and received.
The MIDI component during embedded operation will communicate using a UART serial channel. An EB021 MIDI E-block is available to allow standard MIDI cables to be connected up to a system.
SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
- BYTE Status
MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
- BYTE Data1
MIDI Data Byte - Used as a parameter specific to the specified command
- BYTE Data2
SendPitchChange
Sends out a pitch change command on the specified channel.
- BYTE Channel
Channel to send the pitch change to
- UINT Pitch_Change
New pitch value to use, Default 0x2000
SendNoteOff
Sends a note off command using the channel, note and velocity specified.
- BYTE Channel
- BYTE Note
- BYTE Velocity
SendControl
Sends a control command using the channel, controller and value specified.
- BYTE Channel
- BYTE Controller
- BYTE Value
SendNoteOn
Sends a note on command using the channel, note and velocity specified.
- BYTE Channel
- BYTE Note
- BYTE Velocity
ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message. Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
- BYTE Timeout
SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
- BYTE Channel
- BYTE Note
- BYTE Pressure
ReadData
- BYTE Idx
SendPatch
- BYTE Channel
- BYTE Instrument
SendChannelPressure
- BYTE Channel
- BYTE Pressure
Initialises the MIDI component and sets up the UART.
CommsBaud
Sets the Baud rate of the alt communications channel
- BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
LCDOptions
Controls some of the LCD options
- BYTE Foreground
Range: 0-1
- BYTE Background
Range: 0-1
- BYTE Transparent
Range: 0-1
LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
- BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
ReadDigitalInput
Reads a single digital input.
- BYTE Channel
PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
- BYTE Channel
Range 0-1
- UINT Period
Range: 0-65535
- BYTE Scaler
Range: 0-3
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
- BYTE Channel
Range 0-5
- UINT Duty
LCDCursor
Sets the cursor position for the MIAC display
- BYTE X
Range: 0-21
- BYTE Y
Range: 0-4
WriteTran
Allows a single transistor output to be switched on or off.
- BYTE Channel
Range 1-4
- BYTE Value
0 = Off, 1 = On
LCDClear
Clears the MIAC display
LCDClear
Clears the LCD
Baud Options
Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
Use Flow Control
RTS
Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
CTS
Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Simulations
MIDI Output
Decides if we are using special MIDI output or standard Serial/API Output. Yes: We send the simulation data via a MIDI interface. No: We send the simulation data via the standard COM/API interface.
MIDI Port
Console Columns
Data Source
