Component: Temp / Humidity (DHT22) (Environmental)
Revision as of 10:38, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temp / Humidity (DHT22) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
Example Program showing how to sample the DHT22 sensor and show the temperature and humidity on an LCD. DHT22 Example
GetTempWhole
Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15.
[[File:]] - Return
GetHumidityFloat
Gets the humidity returned by calling SampleSensor as a floating point number. If humidity is 15.8 % then this function would return 15.8.
[[File:]] - Return
GetTempString
Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8".
- STRING Return
GetHumidityString
Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8".
- STRING Return
GetHumidityWhole
Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15.
[[File:]] - Return
GetTempReal
Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8.
[[File:]] - Return
GetHumidityReal
Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8.
[[File:]] - Return
SampleSensor
Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error.
GetTempFloat
Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8.
[[File:]] - Return
Initialise the sensor configuration as set by the component properties
Stes up the I2C bus and initialises the termperature sensor ready for use.
SimSetGyro
Allows the XYZ slider values to be set via the simulation
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
SimSetCompass
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE NumSamples
The number of readings to base the bearing on
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
IOSetOutputPin
- BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
SPIInitialise
- BYTE Channel
OneWireReceiveByte
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
OneWireGetDeviceCount
- BYTE Channel
PWMSetPrescaler
- BYTE Channel
Range: 0 - 11
- BYTE Prescaler
- BYTE Period
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-11
ADCSampleArray10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
SIG Pin
Microcontroller I/O Pin connected to the DHT11 sensor data pin.
Use Checksum
The checksum value is used to ensure the data being received is correct. Yes = Only receive data if checksum is correct No = Ignore checksum
Clock Adjustment
On 8-bit PIC devices the timings can be a little tight as slower clock speeds and so we implement an adjustment factor to allow the sensor to function. Auto mode will attempt to automatically calculate a correct adjustment factor. Manual mode will allow you to set your own adjustment factor.
Simulations
