Component: Gyroscope (EBM009) (EBM Modules)
Revision as of 10:38, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category EBM Modules
Gyroscope component
Interface to the L3G4200D three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Sample program demonstrating the EBM009 Gyroscope Sensor.
The program plots X, Y and Z data onto the LCD screen.
EBM009 Example
GetZ
Returns the previously sampled Z axis data
[[File:]] - Return
GetY
Returns the previously sampled Y axis data
[[File:]] - Return
GetX
Returns the previously sampled X axis data
[[File:]] - Return
SampleDevice
Reads the Axis data from the device. Returns 0 if successful
ReadRegister
Read the data byte at the given address of the device
- BYTE Reg
address of the register to be read
WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
- BYTE Reg
address of register to be written with data byte
- BYTE data
data byte to be written to device register
Initialise the component. Returns 0 if successful
Set up the thermocouple sensor ready for use.
Initialise the sensor configuration as set by the component properties
Stes up the I2C bus and initialises the termperature sensor ready for use.
SimSetGyro
Allows the XYZ slider values to be set via the simulation
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
SimSetCompass
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE NumSamples
The number of readings to base the bearing on
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
IOSetOutputPin
- BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
UARTReceive
- BYTE Channel
ADCSampleAverage10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE Channel
SPIInitialise
- BYTE Channel
OneWireReceiveByte
- BYTE Channel
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
OneWireGetDeviceCount
- BYTE Channel
PWMSetPrescaler
- BYTE Channel
Range: 0 - 11
- BYTE Prescaler
- BYTE Period
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-11
ADCSampleArray10
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 32
- UINT SampleDelay
- UINT Samples
ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE ADCChannel
Range: 0, 3-7
- BYTE SampleCount
Range: 1- 100
- BYTE SampleDelay
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Output Data Rate
Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
X Axis
Y Axis
Z Axis
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Baud Select
Baud rate to be used
Stop Delay
API
Simulations
Simulate Comms
