| Author
| Version
1.0
| Category
Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Current
| [[File:]] -
GetTemperatureData
| Returns the raw register pair value
- UINT
GetTemperatureInt
| Return temperature reading as an integer value in degrees C
| [[File:]] -
GetHumidityInt
| returns the relative Humidity reading as an integer value
| [[File:]] -
GetHumidityReal
| returns the Humidity reading as a float value
| [[File:]] -
GetHumidityData
- UINT
| Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
- BYTE
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
SimSetGyro
| Allows the XYZ slider values to be set via the simulation
| [[File:]] -
X
| [[File:]] -
Y
| [[File:]] -
Z
UpdateAccelerometerData
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
SimSetCompass
| [[File:]] -
X
| [[File:]] -
Y
| [[File:]] -
Z
Read_Bearing
| Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE
NumSamples
| The number of readings to base the bearing on
- UINT
- BYTE
IOSetOutputPin
| Sets the selected digital pin to an output and assigns the output state.
- BYTE
Pin
| Range: 0-29
| [[File:]] -
State
| Range: 0-1
UARTReceive
| Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available.
- BYTE
| Channel Index: Range 0 - UART Bus Count - 1
- BYTE
ADCSampleAverage10
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023. Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
| Delay in us between each sample
- UINT
OneWireScanBus
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE
| Channel Index: Range 0 - I2C Bus Count - 1
- BYTE
SPIInitialise
| Initialsie the SPI module ready for communications
- BYTE
| Channel Index: Range 0 - SPI Bus Count - 1
OneWireReceiveByte
| Receives a byte from the one wire bus a bit at a time
- BYTE
- BYTE
I2CSend
| Transmit a byte using the I2C bus
- BYTE
- BYTE
DataOut
| [[File:]] -
UARTSend
| Send a byte via the UART module
- BYTE
- BYTE
Data
| Data Byte to send. Range: 0-255
OneWireGetDeviceCount
| Returns the number of devices found by the last ScanBus operation.
- BYTE
- BYTE
PWMSetPrescaler
| Sets the prescaler for the PWM output
- BYTE
| Range: 0 - 11
- BYTE
Prescaler
- BYTE
Period
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-11
ADCSampleArray10
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
| 10-bit samples returned from the function
ADCSampleAverage8
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
| Initialise the comms to the Arduino board ready for commands to be sent.
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
Device
VDD
| Analogue Input Channel - Which pin is the analogue input connected to?
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Simulations
