Component: gLCD Font Library (Graphical Library)
gLCD Font Library component
A component designed to simplify the task of creating dynamic fonts for use with graphical displays.
|   | ReadWidth |
| Gets the width of the ASCII character font data | |
|  - BYTE | Character |
| ASCII position so A = 'A' | |
|  - BYTE | Return |
|   | ReadFontStat |
| Collects a stat about the selected font | |
|  - BYTE | Index |
| 0=SpaceColumns, 1=CharacterHeight | |
|  - BYTE | Return |
|   | BPlot |
| Sets a pixel with the current background colour at pixel location X, Y. | |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ClearDisplay |
| This macro clears the display of any previous output by overwriting the entire display with the background colour. | |
|  - VOID | Return |
|   | SetBackgroundColour |
| Specifies the colour of the foreground | |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | ReadASCIILUT |
|  - VOID | Return |
|   | SetForegroundColour |
| Specifies the colour of the foreground. | |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | Initialise |
| The Init macro must be called once to initialise the Graphical LCD display before any other Graphical LCD component macros are called. | |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | ARB4 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
|  - BYTE | Waveform |
|  - VOID | Return |
|   | CLKSRRet |
| Returns the clock source <INT> or <EXT>. | |
| [[File:]] - | Return |
|   | MODPMDEV |
| Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
| [[File:]] - | Degrees |
| Sets PM waveform deviation in degrees (-360 - 360). | |
|  - VOID | Return |
|   | MSTLOCK |
| Sends signal to SLAVE generator to get synchronised | |
|  - VOID | Return |
|   | HILVL |
| Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
| [[File:]] - | HighLevel |
| Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
|  - VOID | Return |
|   | ARB3 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
|  - UINT | Waveform |
|  - VOID | Return |
|   | CALADJ |
| Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
| [[File:]] - | Calibrate |
| Adjust the selected calibration value (-100 - 100). | |
|  - VOID | Return |
|   | STBRet |
| Returns the value of the Status Byte Register in <nr1> numeric format. | |
|  - BYTE | Return |
|   | ARB2 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
|  - UINT | Waveform |
|  - VOID | Return |
|   | EERRet |
| Query and clear execution error number register. | |
|  - STRING | Return |
|   | MODFMSRC |
| Sets FM waveform source to; 0 INT, 1 = EXT. | |
| [[File:]] - | Source |
| Sets FM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MODAMFREQ |
| Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
| [[File:]] - | Frequency |
| Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
|  - VOID | Return |
|   | ESE |
| Sets the Standard Event Status Enable Register to the value of <nrf>. | |
|  - BYTE | Value |
| Value of register 0-255 | |
|  - VOID | Return |
|   | ARB1 |
| Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
|  - UINT | Waveform |
| 16 Bit binary number for arbitrary waveform. | |
|  - VOID | Return |
|   | ARB4DEFRet |
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
|  - STRING | Return |
|   | CLS |
| Clears status byte register of the interface. | |
|  - VOID | Return |
|   | MSTRELOCK |
| Resynchronises the two generators in MASTER-SLAVE mode. | |
|  - VOID | Return |
|   | NOISLVL |
| Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
|  - BYTE | Percent |
| Sets the output noise level in percent. (0 - 50) | |
|  - VOID | Return |
|   | LOCKMODE |
| Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
|  - BYTE | Mode |
| Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
|  - VOID | Return |
|   | ADDRESSRet |
| Returns the instruments address | |
|   | MODPMSRC |
| Sets PM waveform source to; 0 INT, 1 = EXT. | |
| Sets PM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MODPWMSRC |
| Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
| Sets PWM waveform source (0 = INT, 1 = EXT). | |
|  - VOID | Return |
|   | MOD |
| Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
|  - BYTE | Modulation |
| Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
|  - VOID | Return |
|   | ISTRet |
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
|   | LRNRet |
| Returns the complete setup of the instrument as a binary data block | |
|   | OPCRet |
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
|   | PULSRANGE |
| Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
|  - BYTE | Range |
| Sets the pulse rise and fall range. (1, 2 or 3) | |
|  - VOID | Return |
|   | TSTRet |
| The generator has no self test capability and the response is always 0 <rmt>. | |
|   | BSTTRGPOL |
| Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
| [[File:]] - | Slope |
| Set the burst trigger slope (0 = POS, 1 = NEG). | |
|  - VOID | Return |
|   | ARB3Ret |
| Returns the binary-data from an existing abbitrary wavefrom memory location. | |
|  - UINT | Return |
|   | BSTPHASE |
| Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
| Sets the burst phase in degrees (-360 - 360) | |
|  - VOID | Return |
|   | SWPTRGPER |
| Sets the sweep trigger period to <nrf> seconds | |
| [[File:]] - | Seconds |
| Set the sweep trigger period in seconds. | |
|  - VOID | Return |
|   | PULSDLY |
| Sets the waveform delay to <nrf> sec | |
| [[File:]] - | Sec |
|  - VOID | Return |
|   | Initialise |
| Opens the COM port ready for communications. | |
|  - VOID | Return |
