| Author
Matrix Ltd
| Version
1.8
| Category
Graphical Color
GLCD (SSD1351) component
Graphical display component based on the SSD1251 16-bit colour graphical controller IC.
SSD1351 gLCD Example File
SSD1351 Example
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
| [[File:]] -
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
SendData
- BYTE
Byte
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
InvertDisplay
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros
MODPMSHAPE
| Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE
Shape
| Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
| Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE
Waveform
CLKSRRet
| Returns the clock source <INT> or <EXT>.
| [[File:]] -
MODPMDEV
| Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
| [[File:]] -
Degrees
| Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
| Sends signal to SLAVE generator to get synchronised
HILVL
| Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
| [[File:]] -
HighLevel
| Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
| Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT
Waveform
WAVE
| Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE
WaveType
| 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
| Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
| [[File:]] -
Calibrate
| Adjust the selected calibration value (-100 - 100).
STBRet
| Returns the value of the Status Byte Register in <nr1> numeric format.
- BYTE
ARB2
| Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT
Waveform
EERRet
| Query and clear execution error number register.
- STRING
MODFMSRC
| Sets FM waveform source to; 0 INT, 1 = EXT.
| [[File:]] -
Source
| Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
| Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
| [[File:]] -
Frequency
| Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
| Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE
Value
| Value of register 0-255
ARB1
| Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT
Waveform
| 16 Bit binary number for arbitrary waveform.
ARB4DEFRet
| Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING
CLS
| Clears status byte register of the interface.
MSTRELOCK
| Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
| Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE
Percent
| Sets the output noise level in percent. (0 - 50)
LOCKMODE
| Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE
Mode
| Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
| Returns the instruments address
| [[File:]] -
MODPMSRC
| Sets PM waveform source to; 0 INT, 1 = EXT.
| [[File:]] -
Source
| Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
| Sets PWM waveform source to; 0 = INT, 1 = EXT.
| [[File:]] -
Source
| Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
| Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE
Modulation
| Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
| [[File:]] -
LRNRet
| Returns the complete setup of the instrument as a binary data block
| [[File:]] -
OPCRet
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
| [[File:]] -
SWPTYPE
| Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE
Type
| Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
| Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE
Range
| Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
| The generator has no self test capability and the response is always 0 <rmt>.
| [[File:]] -
BSTTRGPOL
| Sets the burst trigger slope to; 0 = POS, 1 = NEG.
| [[File:]] -
Slope
| Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
| Returns the binary-data from an existing abbitrary wavefrom memory location.
- UINT
BSTPHASE
| Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
| [[File:]] -
Degrees
| Sets the burst phase in degrees (-360 - 360)
IDNRet
| Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING
ReturnIDN
- STRING
SWPTRGPER
| Sets the sweep trigger period to <nrf> seconds
| [[File:]] -
Seconds
| Set the sweep trigger period in seconds.
PULSDLY
| Sets the waveform delay to <nrf> sec
| [[File:]] -
Sec
| Opens the COM port ready for communications.
Pixel Width
Pixel Height
Flip Horizontal
| Allows the horizontal axis to be flipped for displays that run right to left.
Flip Vertical
| Allows the vertical axis to be flipped for displays that run bottom to top.
Flip Colour
| Allows the colour index to be flipped for displays that run blue, green, red.
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Chip Select (CS)
| Chip select pin connection
Reg Select (RS)
Data (SD)
| LED backlight strobe pin connection
Serial Clock (SCK)
| Reset pin connection
Reset (RST)
| Instruction / Command pin connection
Simulations
