Component: FTDI (FTD2XX) (Third Party)
Revision as of 10:43, 17 November 2021 by Wiki bot (talk | contribs)
Category Third Party
FTDI (FTD2XX) component
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. For more details refer to the D2XX_Programmers_Guide from FTDI.
FT_GetStatus
Gets the device status including number of characters in the receive queue, number of characters in the transmit queue, and the current event status.
[[File:]] - Handle
Handle of the device.
[[File:]] - RxQueueLength
Pointer to a variable of type DWORD which receives the number of characters in the receive queue.
[[File:]] - TxQueueLength
Pointer to a variable of type DWORD which receives the number of characters in the transmit queue.
[[File:]] - EventStatus
Pointer to a variable of type DWORD which receives the current state of the event status.
FT_ClrRts
This function clears the Request To Send (RTS) control signal.
[[File:]] - Handle
FT_Write
Write data to the device.
[[File:]] - Handle
- BYTE Buffer
Pointer to the buffer that contains the data to be written to the device.
- ULONG Bytes
Number of bytes to write to the device.
- ULONG Count
Pointer to a variable of type DWORD which receives the number of bytes written to the device.
FT_Read
Read data from the device.
[[File:]] - Handle
- BYTE Buffer
Pointer to the buffer that receives the data from the device.
- ULONG Bytes
Number of bytes to be read from the device.
- ULONG Count
Pointer to a variable of type DWORD which receives the number of bytes read from the device.
FT_SetFlowControl
This function sets the flow control for the device.
[[File:]] - Handle
- UINT FlowControl
Flow setting 0=None, 0x0100=RTS/CTS, 0x0200=DTR/DSR, 0x0400=XON/XOFF
- BYTE Xon
Character used to signal Xon. Only used if flow control is Xon/Xoff
- BYTE Xoff
Character used to signal Xoff. Only used if flow control is Xon/Xoff
FT_GetModemStatus
Gets the modem status and line status from the device.
[[File:]] - Handle
[[File:]] - ModemStatus
Pointer to a variable of type DWORD which receives the modem status and line status from the device.
FT_SetBreakOn
Sets the BREAK condition for the device.
[[File:]] - Handle
FT_CreateDeviceInfoList
This function builds a device information list and returns the number of D2XX devices connected to the system. The list contains information about both unopen and open devices.
[[File:]] - DevCount
Unsigned long array used to store the number of devices connected
FT_SetTimeouts
This function sets the read and write timeouts for the device.
[[File:]] - Handle
[[File:]] - ReadTimeout
Read timeout in milliseconds.
[[File:]] - WriteTimeout
Write timeout in milliseconds.
FT_SetBitMode
Enables different chip modes.
[[File:]] - Handle
- BYTE Mask
Required value for bit mode mask. This sets up which bits are inputs and outputs. A bit value of 0 sets the corresponding pin to an input, a bit value of 1 sets the corresponding pin to an output.
- BYTE Mode
0=Reset / 1=AsyncBB / 2=MPSSE / 4=SyncBB / 8=MCUHost / 16=FastOpto / 32=CBUS / 64=SyncFIFO
FT_SetRts
This function sets the Request To Send (RTS) control signal.
[[File:]] - Handle
FT_GetDeviceInfoDetail
This function returns an entry from the device information list.
- ULONG Index
Index of the entry in the device info list.
- ULONG Flags
Pointer to unsigned long to store the flag value.
- ULONG Type
Pointer to unsigned long to store device type.
- ULONG ID
Pointer to unsigned long to store device ID.
- ULONG LocID
Pointer to unsigned long to store the device location ID.
- BYTE SerNum
Pointer to buffer to store device serial number as a null terminated string
- BYTE Descript
Pointer to buffer to store device description as a null-terminated string
[[File:]] - TempHandle
Pointer to a variable of type FT_HANDLE where the handle will be stored
FT_Close
Close an open device.
[[File:]] - Handle
FT_ClrDtr
This function clears the Data Terminal Ready (DTR) control signal.
[[File:]] - Handle
FT_Purge
This function purges receive and transmit buffers in the device.
[[File:]] - Handle
[[File:]] - Mask
Used to determine which buffer to purge, 1=Rx / 2=Tx / 3=Both
FT_GetQueueStatus
Gets the number of bytes in the receive queue.
[[File:]] - Handle
Pointer to a variable of type DWORD which receives the number of bytes in the receive queue.
FT_SetDataCharacteristics
This function sets the data characteristics for the device.
[[File:]] - Handle
- BYTE WordLength
Number of bits per word - Must be 7 or 8
- BYTE StopBits
Number of stop bits - Must be 1 or 2
- BYTE Parity
Parity 0=None / 1=Odd / 2=Even / 3=Mark / 4=Space
FT_SetBreakOff
Resets the BREAK condition for the device.
[[File:]] - Handle
FT_SetDivisor
This function sets the baud rate for the device. It is used to set non-standard baud rates.
[[File:]] - Handle
- UINT Divisor
Divisor.
FT_SetBaudRate
[[File:]] - Handle
- ULONG BaudRate
Baud rate.
FT_SetDtr
This function sets the Data Terminal Ready (DTR) control signal.
[[File:]] - Handle
FT_Open
Open the device and return a handle which will be used for subsequent accesses.
[[File:]] - Device
Index of the device to open. Indices are 0 based.
[[File:]] - ft_Handle
Pointer to a variable of type FT_HANDLE where the handle will be stored. This handle must be used to access the device.
ScanFor232
Scans for a FTDI D2XX device, returnes true if at least one device was found.
[[File:]] - Return
FT_ResetDevice
This function sends a reset command to the device.
[[File:]] - Handle
FT_SetChars
This function sets the special characters for the device.
[[File:]] - Handle
- BYTE EventCh
Event character.
- BYTE EventChEn
0 if event character disabled, non-zero otherwise.
- BYTE ErrorCh
Error character.
- BYTE ErrorChEn
0 if error character disabled, non-zero otherwise.
DrawRectangle
Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE Waveform
CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
Sends signal to SLAVE generator to get synchronised
HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT Waveform
WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT Waveform
EERRet
Query and clear execution error number register.
- STRING Return
MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE Value
Value of register 0-255
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING Return
CLS
Clears status byte register of the interface.
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE Percent
Sets the output noise level in percent. (0 - 50)
LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
Returns the instruments address
[[File:]] - Return
MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING ReturnIDN
- STRING Return
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Opens the COM port ready for communications.
A text label for the component's panel component.
Simulations
