Component: Switch (Push, Panel) ()
Revision as of 10:44, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Push, Panel) component
Large round push switch with chrome bezel for panel mounting.
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
GetValue
Get the Named property value.
- STRING Name
- STRING Return
Transaction_Write
Attempt to write Length number of bytes to the I2C slave from the given Buffer. Ensure that the Buffer is large enough. Returns the number of bytes written, the caller should check that this matches requested Length
- BYTE Buffer
Buffer of bytes to write to the I2C
- UINT Length
Master_Stop
Output a Master Stop
Slave_Init
Initialise the Slave with the given Address, or range of Addresses. Only address bits that have a corresponding bit set in the Mask will be compared with the incoming bus address.
- BYTE Address
7 Bit Address of this device (Bit 0 is ignored)
- BYTE Mask
Bit mask used to compare addresses
Master_Uninit
Uninitialise the Master
Slave_Status
Returns the Slave Status. Bit 0 = 1 Indicates address/data byte available in the buffer to read Bit 5 = 1 Indicates that the last byte received or transmitted was data (else address)
GetConsoleHandle
Obtains the CAL console handle
[[File:]] - Return
Slave_TxByte
Send a data byte, returns Ack/Nak from Master 0=Ack=More, 1=Nak=Last
- BYTE Data
Transaction_Uninit
Uninitialise the I2C interface
Slave_RxByte
Returns the data received, and sends either Ack or Nak Set parameter Last as: 1=Last=Nak, 0=Ack=More
- BYTE Last
Sends Ack if 0, else Nak
SetValue
Change Named property to new Value. If "CHANNEL" the ports will be also updated from the fcd
- STRING Name
- STRING Value
port value as string
Master_Init
Initialise the Master
Master_Start
Output a Master Start sequence
Transaction_Read
Attempt to read Length number of bytes from the I2C slave to the given Buffer. Ensure that the Buffer is large enough. Returns number of bytes read, caller should check that this matches requested Length
- BYTE Buffer
Buffer to store the incoming byte data
- UINT Length
Number of bytes to read
Master_TxByte
Send a data byte and collects the acknowledge from the slave. Returns 0 for Ack received. Returns 1 for Ack not received - slave not responding.
- BYTE Data
Data byte to write to the I2C bus
Master_Restart
Output a Master Restart sequence
Master_RxByte
Returns a received data byte. Set Last=0 if there is following more Master_RxByte macros Set Last=1 if this is the last Master_RxByte and it is followed with Master_Stop. If Last = 1 the I2C bus will be presented with a 'Nack' condition.
- BYTE Last
Range: 0-1 - 0 = Not the last byte to receive, 1 = last byte to receive
Transaction_Initialise
Initialise the I2C interface to communicate with a Slave device at Address Returns 0 on fail, 1 on success
- BYTE Address
7-bit I2C Address without the shift for the R/W bit
GetList
returns Named property List as filter string
- STRING Name
- STRING Return
MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE Waveform
CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
Sends signal to SLAVE generator to get synchronised
HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT Waveform
WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT Waveform
EERRet
Query and clear execution error number register.
- STRING Return
MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE Value
Value of register 0-255
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING Return
CLS
Clears status byte register of the interface.
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE Percent
Sets the output noise level in percent. (0 - 50)
LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
Returns the instruments address
[[File:]] - Return
MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING ReturnIDN
- STRING Return
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Opens the COM port ready for communications.
Connection
Chip pin to which this switch is connected.
Polarity
Sets whether activating the switch sets the chip pin high or low.
Debounce (ms)
Time in milliseconds allowed for the switch to stabilise after a change of state. NB) This applies only when using the component macros to read the button state- chip pin is not debounced.
Simulations
Operation
Latching - click the button to turn the switch on, click again to turn it off. Momentary - click the button to turn it on, release the mouse to turn it off.
