Component: Injector (File) (Test Injectors)
| Author | Matrix Ltd |
| Category | Test Injectors |
Injector (File) component
Comms data injector to allow data to be streamed to and from a file during simulation. The component will read data from the incoming file and write data to the outgoing file.
Example to log the bytes sent via the UART RS232 component to a file as comma separated decimal numbers.
LogToFile
Contents of the file in the Flowcode project directory after running the simulation.
| UARTBaud | |
| Channel | |
| Rate | |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
| [[File:]] - | Return |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| UARTSend | |
| Channel | |
| Data | |
