Author
Matrix Ltd.
Version
2.0
Category
Comms: System
Modbus Slave component
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
Example master program to control the slave. The example reads the 8 switches connected to PortD. If the switch values change then the new value is send to the slave.
Modbus Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0-7 state to eight LEDs connected to PortD.
Modbus Slave Example
Master and Slave example using vNet
Example of communicating using Modbus Master and Slave using two instances of Flowcode and the vNet injector component.
ModbusMasterDemo
ModBusSlaveDemo
Addressing
Data Type
Common name
Starting address
Ending Address
Flowcode Start Address
Flowcode End Address
Modbus Coils
Bits, binary values, flags
00001
10000
0
9999
Digital Inputs
Binary inputs
10001
30000
0
19999
Analog Inputs
Binary inputs
30001
40000
0
9999
Modbus Registers
Analog values, variables
40001
60000
0
19999
ReadHoldingRegister
Reads the value of a single holding register.
- UINT
Address
Coil Address
- UINT
SetCoil
Sets the state of a single digital coil.
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetDigitalInput
Sets the state of a single digital input.
- UINT
Address
Coil Address
- BYTE
State
0=off, 1=on
SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT
SlaveAddress
ChangeFrameType
Default frame type is the type set in the component properties.
- BYTE
Type
0 = Modbus RTU / 1 = Modbus ASCII
ReadCoils
Reads the state of up to eight digital coils. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
Range 1-8
- BYTE
SetBaudRate
Allows the Baud Rate to be controlled dynamically overriding the default rate specified by the Baud component property.
- BYTE
Rate
SetHoldingRegister
Sets the state of a single holding register.
- UINT
Address
Coil Address
- UINT
Value
Analogue Value range 0 - 65535
ReadAnalogInput
Reads the value of a single analogue input.
- UINT
Address
Coil Address
- UINT
CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
- BYTE
ChangeBaud
Changes the UART Baud rate. 1 = 1200 / 2 = 2400 / 3 = 4800 / 4 = 9600 / 5 = 19200 / 6 = 31250 7 = 38400 / 8 = 57600 / 9 = 115200
- BYTE
Baud
The new baud rate (0=1200, 9=115200)
ReadDigitalInputs
Reads the state of up to eight digital inputs. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
- BYTE
AddressCount
Range 1-8
- BYTE
GetLastIncoming
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
- BYTE
Index
Range: 0-3
- UINT
SetAnalogInput
Sets the state of a single analogue input.
- UINT
Address
Coil Address
- UINT
Value
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
TX
RX
Baud Options
Bus
Specifies the bus mode being used, RS232 allows you to connect a single master node to a single slave node. RS485 allows you to connect a single master node to multiple slave nodes.
Timeout
Timeout in milliseconds used to dictate the maximum time to wait in milliseconds between bytes in a packet. Range: 1 - 255
Frame Type
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
Slave ID Bytes
Slave Address
Reply Delay
Delay in micro seconds to wait before transmitting a reply
Maintain Stats
Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Console Columns
Data Source
API
Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
Starting Address
Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Starting Address
Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
Simulations
