Component: Range Time of Flight (VL53L0X) (Light)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Light |
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed. Detector
ReadModel | |
Collects the model number from the sensor | |
- BYTE | Return |
ReadRevision | |
Collects the revision number from the sensor | |
- BYTE | Return |
ReadDistance | |
Read the current distance in mm. Returns -1 if the sensor timed out during the read operation. | |
[[File:]] - | Return |
ReadRegister | |
A simple example showing a generic way to read a register using I2C. | |
- BYTE | Address |
- BYTE | Return |
WriteRegister | |
A simple example showing a generic way to write a register using I2C. | |
- BYTE | Address |
- BYTE | Data |
- VOID | Return |
Initialise | |
