API Sound.QueueEx
<sidebar>API contents</sidebar> Queues a sound for playing, with the format provided
HANDLE Sounds
- The handle of the sound object to queue to
BYTE[] Data
- The array to play data from
ULONG ByteOffset
- The byte-offset in the array to start at
UINT SampleFormat
- Format of the samples
- Typical values for this parameter:
Name Description Fmt_Signed8 Source data is in the range -128 to 127 Fmt_Unsigned8 Source data is in the range 0 to 255 Fmt_Signed16 Source data is in the range -32768 to 32767 Fmt_Unsigned16 Source data is in the range 0 to 65535 Fmt_Signed32 Source data is a signed 32-bit value Fmt_Unsigned32 Source data is an unsigned 32-bit value Fmt_Float32 Source data is a 32-bit float from 0 to 1 Fmt_Float64 Source data is a 64-bit float from 0 to 1 Fmt_Mono Set this flag to set a single source element per sample Fmt_Stereo Set this flag to two source elements per sample
ULONG Elements
- The number of sample elements to play
FLOAT RateMul
- A multiplier to the sounds sample rate
- The default value for this parameter is: 1
Returns true if the operation is a success, else false
- Add to a calculation icon:
result = ::Sound.QueueEx(sounds, _arraydata, byteoffset, ::Sound.Fmt_Signed8, elements, ratemul)
