Component: Temp / Humidity (SHT31) (Environmental)
Revision as of 13:30, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
GetTemperatureReal
Return temperature reading as a float value in degrees C
- FLOAT Return
GetTemperatureData
Returns the raw register pair value
GetTemperatureInt
Return temperature reading as an integer value in degrees C
- INT Return
GetHumidityInt
returns the relative Humidity reading as an integer value
- INT Return
GetHumidityReal
returns the Humidity reading as a float value
- FLOAT Return
GetHumidityData
Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
Address
Selects the correct device address based on the ADDR pin connection to VDD or VSS.
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
API
Simulations
Simulation Comms
