API File.Buffer.Open
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import of API auto-gen)
wiki page name
File.BufferOpen
Opens the existing file as a circular buffer
STRING Filename
The name of an existing file to open
BOOL Write
Set to enable write access
BOOL Monitor
Set to enable monitoring of the file
HANDLE
Calling in a calculation:
  • Add to a calculation icon: result = ::File.Buffer.Open("filename", true, false)
