Component: GLCD (ILI9163C) (Graphical Color)
Revision as of 13:33, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (ILI9163C) component
Graphical display component designed to work with the ILI9163C 16-bit colour graphical controller IC.
ReadFontWidth
- BYTE Font
- BYTE Character
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Plot
- UINT X1
- UINT Y1
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
FastPlot
SetDisplayOrientation
- BYTE Orientation
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
- UINT X1
- UINT Y1
Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Pixel Width
Pixel Height
Offset X
Offset Y
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Data
Data pin connection
Clock
Clock pin connection
Chip Select
Chip select pin connection
A0
Reset
Reset pin connection
LED
Simulations
