Component: GLCD (SH1106) SPI (Graphical Monochrome)
Revision as of 13:33, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Monochrome
GLCD (SH1106) SPI component
Graphical display component designed to work with the SH1106 type monochrome displays. Transfers data using a 4-wire SPI interface.
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
Write_Command
- BYTE Command
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Pixel Width
Pixel Height
Monochrome
Foreground Color
Background Color
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Simulate Comms
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
API
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
DC
Reset
Reset pin on the display, used during initialise to force a clean startup of the display
Simulations
