| Author
Matrix Ltd
| Version
1.3
| Category
Graphical Monochrome
GLCD (SSD1322) Parallel component
Graphical display component designed to work with the SSD1322 type monochrome displays. Compatible with 6800 and 8080 type 8-bit parallel displays.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
| Specifies the colour of the background.
- BYTE
Pixel_Colour
| 0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
Pixel_Colour
| 0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Width
Pixel Height
Monochrome
Foreground Color
Background Colour
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Enable Delay
| Time in micro seconds to wait before and after toggling the enable pin.
Interface Type
| Sets the display interface type, this wil lhave to match the gLCD hardware setting.
CS
| Chip select to address the first controller IC
R/W / Write
| 6800 - Read / Write Selection Pin 8080 - Write Enable Pin
Enable / Read
| 6800 - Enable Pin 8080 - Read Enable Pin
Data/Command
| Data / Command selection pin
Data0
| Data Pin 0
Data1
| Data Pin 1
Data2
| Data Pin 2
Data3
| Data Pin 3
Data4
| Data Pin 4
Data5
| Data Pin 5
Data6
| Data Pin 6
Data7
| Data Pin 7
Reset
| Display reset pin
Simulations
