| Author
Matrix Ltd
| Version
1.9
| Category
Graphical Monochrome
GLCD (SSD1327) I2C component
Graphical display component based on the I2C version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
ControlDisplay
| Allows the display to be switched on and off
- BYTE
Control
| 0=Off, 1=On
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
SetShadeIntensity
| Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
- BYTE
Shade
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
InvertDisplay
Pixel Width
Pixel Height
Flip
| Determines if the display is flipped or not
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Simulate Comms
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the injector component on the panel to interact with to provide comms simulation.
I2C Address
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Simulations
