Author
Matrix TSL
Version
2.0
Category
LEDs
RGB LED APA102C component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
- FLOAT
Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
- UINT
LED
LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE
ColIdx
0 = R, 1 = G, 2 = B
- BYTE
SetBrightnessByte
- BYTE
Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
DrawLine2D
Draws a line on a 2D array of LEDs
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
R
- BYTE
G
- BYTE
B
SetLEDColour
- UINT
LED
- BYTE
R
- BYTE
G
- BYTE
B
SetAllLEDColour
Sets the colour of all the LEDs in RAM
- BYTE
R
- BYTE
G
- BYTE
B
Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
ShiftLEDs1D
Shifts the LED colours in 1D and wraps
- BYTE
Direction
0 = Forwards, 1 = Backwards
- BYTE
DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
DrawLine3D
Draws a line on a 3D array of LEDs
- UINT
X1
- UINT
Y1
- UINT
Z1
- UINT
X2
- UINT
Y2
- UINT
Z2
- BYTE
R
- BYTE
G
- BYTE
B
GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
- UINT
X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
- INT
X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
- INT
Y
- BYTE
DataMode
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT
X
- UINT
Y
- UINT
Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
Z1
- BYTE
X2
- BYTE
Y2
- BYTE
Z2
- BYTE
DrawStyle
- BYTE
R
- BYTE
G
- BYTE
B
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the WS2801 ICs in the chain.
ShiftLEDs3D
- INT
X
- INT
Y
- INT
Z
- BYTE
DataMode
LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
Total number of LEDs in the design
LED Columns
Number of horizontal LEDs - X axis
Column Spacing
X Spacing Between LEDs on the Panel
LED Rows
Number of vertical LEDs - Y axis
Row Spacing
Y Spacing Between LEDs on the Panel
LED Layers
Number of LED layers - Z axis
Layer Spacing
Z Spacing Between LEDs on the Panel
Flip X
Flips the X axis if the LEDs are wired from the right hand side of the display.
Flip Y
Flips the Y axis if the LEDs are wired from the bottom side of the display.
Flip Z
Flips the Z axis if the LEDs are wired from the upper most side of the display.
LED Current Usage
Data Pin
LED Data Pin - Connected to the Data In pin of the first WS8201 IC.
Clock Pin
LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC.
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
Output Mode
Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O
Simulations
API
