Component: Switch (Push, Panel) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
Switch (Push, Panel) component
Large round push switch with chrome bezel for panel mounting.
Switch
(5V / 11K) * 10K = 4.54545V
